1975 1.8, stalls out |
Loretoron |
Jul 18 2022, 12:49 PM
Newbie Group: Members Posts: 1 Joined: 20-May 22 From: Placerville, California Member No.: 26,565 Region Association: Northern California |
My 914 starts, runs rough, then dies , I cannot keep it running. any ideas what to do? Thanks, Ron
Geezer914 |
Jul 18 2022, 03:57 PM
Geezer914 Group: Members Posts: 1,451 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States |
Check for vacuum leaks. 1.8's run like crap if there is even a slight vacuum leak.
wonkipop |
Jul 18 2022, 05:35 PM
Advanced Member Group: Members Posts: 4,405 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
Check for vacuum leaks. 1.8's run like crap if there is even a slight vacuum leak. (IMG:style_emoticons/default/agree.gif) check all your hoses, throttle body to plenum gasket, intake boot from AFM to TB for cracks, make sure no vacuum leaks. check the oil fill cap that its tight and that the o-ring is good. the cap itself is the PCV valve. there is more. but do all that first. if there is no vacuum leaks, there is a chance its firing off the cold start injector. which will let it run about 5 to 10 seconds at most. but that the injectors are not opening. so no go after the initial injection of fuel. did this problem suddenly happen? or develop gradually? |
Lo-Fi Version | Time is now: 13th June 2024 - 07:10 AM |
