> Optimum rpm range around town and cruising around 70mph?
Geezer914
post Jul 20 2022, 05:31 AM
Geezer914
What is the optimum rpm range for cruising around town or on the highway at 70 mph?
Optimusglen
post Jul 20 2022, 10:38 AM
Shoot... I'm pushing 4k in my 6 at 70-75ish (IIRC)
Wonder if I should go bigger tires...
VaccaRabite
post Jul 20 2022, 11:47 AM
En Garde!
QUOTE(Optimusglen @ Jul 20 2022, 12:38 PM) *
If the gear ratios are the same in a /6 as they are in a /4 - then yes you need taller tires. Your speedo must be way off too. Guessing you are using a 50 series tire?
Zach
DRPHIL914
post Jul 20 2022, 12:43 PM
Dr. Phil
QUOTE(VaccaRabite @ Jul 20 2022, 01:47 PM) *
Zach
(IMG:style_emoticons/default/agree.gif) might be, what are you using?
i am running 205/55-16 thats with in an 1/8" of stock 914 tire diameter , its close between a 205/50 and 205/55 but /50 on a 15" are definitely smaller than what the german engineers had in mind when the set the gearing ratios.
Geezer914   Optimum rpm range around town and cruising around 70mph?   Jul 20 2022, 05:31 AM
930cabman   What is the optimum rpm range for cruising around...   Jul 20 2022, 05:51 AM
BeatNavy   For what purpose? Engine longevity/cooling, momen...   Jul 20 2022, 05:57 AM
GregAmy   Chris Foley told me the same: use revs 3k or above...   Jul 20 2022, 06:25 AM
emerygt350   My stock 2.0 definitely likes 3k. At 60 in fifth ...   Jul 20 2022, 06:32 AM
DRPHIL914   My stock 2.0 definitely likes 3k. At 60 in fifth...   Jul 20 2022, 07:37 AM
VaccaRabite   Yup. The rule of thumb is that 70mph at 3K rpm is...   Jul 20 2022, 08:42 AM
mgphoto   Biggest factor on these little cars for cruising R...   Jul 20 2022, 09:26 AM
Optimusglen   Shoot... I'm pushing 4k in my 6 at 70-75ish (I...   Jul 20 2022, 10:38 AM
VaccaRabite   Shoot... I'm pushing 4k in my 6 at 70-75ish (...   Jul 20 2022, 11:47 AM
DRPHIL914   Shoot... I'm pushing 4k in my 6 at 70-75ish ...   Jul 20 2022, 12:43 PM
Dr Evil   Shoot... I'm pushing 4k in my 6 at 70-75ish ...   Jul 21 2022, 10:08 AM
Optimusglen   Shoot... I'm pushing 4k in my 6 at 70-75ish ...   Jul 21 2022, 02:00 PM
VaccaRabite   [quote name='VaccaRabite' post='3016656' date='Ju...   Jul 22 2022, 10:36 AM
Optimusglen   You have to have different gearing as Mike note...   Jul 25 2022, 02:34 PM
Cairo94507   I think I am at about 2,600 RPM at 70 MPH; I am ru...   Jul 20 2022, 12:19 PM
windforfun   I prefer 3K rpm or slightly more for general respo...   Jul 20 2022, 02:48 PM
emerygt350   I run 225/50r16s. My speedo is about 4 mph fast at...   Jul 20 2022, 03:05 PM
Olympic 914   I run 225/50r16s. My speedo is about 4 mph fast a...   Jul 21 2022, 06:56 AM
wonkipop   I run 225/50r16s. My speedo is about 4 mph fast ...   Jul 21 2022, 07:18 AM
wonkipop   near enough around 3K at 70mph in 5. correct profi...   Jul 20 2022, 05:02 PM
Lockwodo   Has anyone come up with an electric fan arrangemen...   Jul 20 2022, 05:45 PM
emerygt350   I doubt an electric would be useful. The actual m...   Jul 20 2022, 08:10 PM
wonkipop   I doubt an electric would be useful. The actual ...   Jul 21 2022, 01:26 AM
mlindner   If any time applying load, I down shift so RPM is ...   Jul 21 2022, 08:53 AM
emerygt350   You would think so... But it is definitely reading...   Jul 21 2022, 05:18 PM
barefoot   With my 235-55 ZR17's (27"OD) I'm ru...   Jul 25 2022, 08:19 AM
Jamie   With my 235-55 ZR17's (27"OD) I'm r...   Jul 25 2022, 09:30 AM
- Lo-Fi Version Time is now: 12th May 2026 - 06:43 PM
