What distributor should I use for modified engine? |
pistonboy |
Jul 22 2022, 05:37 PM
Newbie Group: Members Posts: 38 Joined: 26-October 15 From: California Member No.: 19,305 Region Association: None |
I have just obtained a modified engine from someone who lost interest in their project and sold the engine to me.
It has never been started. It will be used mostly for casual driving in the country. It has: 82 mm stroke 103 mm bore cam for carbs enlarged valves I will use a 38/38 parallel carb for the first 1,000 miles to guarantee all cylinders are receiving equal fuel/air charge. After 1,000 miles, I will change to 44IDF carbs (I was told 48IDF carbs could work). But, I have not chosen a distributor. I do not want the modern computer controlled distributors. I would prefer one of the older and simpler SVDA designs of of VW or Bosch. Since my driving is moderate with occasional brisk accelerations, my demands on the engine are simple. I suspect more than one distributor will work. Any suggestions? My question is "What distributors would be good to use?" Thank you. |
GregAmy |
Jul 22 2022, 06:34 PM
Advanced Member Group: Members Posts: 2,311 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States |
Not clear what you mean by "no computer controlled distributor" - are you insisting on points and condensor? - but the self-contained 123 disty is your bird.
If that's not what you want...well, then pick one, bro. Suggest you research which curve you want, because others are fixed and not change-able like the 123. You'll want to really look into that, given it's apparently a 2.7L 4-banger (or is it a 4L 6-banger?) GA |
pistonboy |
Jul 22 2022, 06:49 PM
Not clear what you mean by "no computer controlled distributor" - are you insisting on points and condensor? - but the self-contained 123 disty is your bird. If that's not what you want...well, then pick one, bro. Suggest you research which curve you want, because others are fixed and not change-able like the 123. You'll want to really look into that, given it's apparently a 2.7L 4-banger (or is it a 4L 6-banger?) GA Thanks for replying. No, I do not want points and condenser, but I can add a Pertronix module to get that. I was thinking of the 123 Distributor when I said "no computer controlled distributor" As I see it, the problem is knowing what curve to use. When an engine is this modified, I don't think previous curves from previous distributors apply anymore. To truly know what curve it should have, would require experienced engineers from factories with expensive test equipment, and lots of testing. I don't have that. I suspect a moderate, nonextreme curve would be best. This would come from a moderate, nonextreme distributor. This is what I am seeking from the folks on this forum. |
Lo-Fi Version | Time is now: 5th June 2024 - 04:51 AM |
