914 fuse confirmation |
MM1 |
Jul 24 2022, 12:02 PM
914 obsession continues Group: Members Posts: 608 Joined: 9-May 18 From: Thousand Oaks, CA Member No.: 22,105 Region Association: Southern California |
I’m trying to replace fuses in the 914 which I’ve never done before. Can you please tell me if this diagram is correct? (I got it from a thread on 914 World.) It shows that all fuses are 8 amp except for the wiper motor which is 16 amp-it says the two fuses that are to the far right are an 8 and a 16 for unused circuits.
The picture of mine shows it has a 16 amp in the first slot to the left which is a tail lamp and luggage lamp-if the diagram is correct this should be an eight amp. |
dr914@autoatlanta.com |
Jul 25 2022, 01:18 PM
914 Guru Group: Members Posts: 7,900 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
owners manual or appendix of the book 914 "tech tips 700" the 70-73 used 8 and 25 the 74-76 8 and 16 amp fuses. Please make sure you put a fuse cover over the fuses when you are done, too easy to knock them out when getting in and out of the car
Lo-Fi Version | Time is now: 17th June 2024 - 06:47 AM |
