| Chris914n6 |
Jul 26 2022, 03:04 AM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,564 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Logic, according to my brain...
In 2000 I installed a Nissan VQ30, 3.0L from a 97 Maxima. 190hp 205tq and it was great. Then things happened (rusted battery tray). Then it sat for a decade (recession). The engine now overheats the cooling system like a bad head gasket. Likely from aluminum erosion from sitting too long (other signs). Fixing that requires complete disassembly down to a short block. Soooo.... I decided to move up to a VQ35, 03 Maxima 3.5L +80hp!!! (that's 42% more) Here's the rub. To get the VQ30 to fit I moved everything forward 1.5". Renegade sbc trans blocks, shortened shift rod, small hole in the truck. To fit the VQ35 as-is I would need to move it back, likely to stock location, to clear the variable cam timing stuff. That means a new cross mount, new shift rod, redo exhaust, plus new harness and ms3pro ecu ($$$$). Turns out the gearheads at Maxima.org like to upgrade too. They created a VQ30/35 hybrid. It's a VQ35 engine with VQ30 ecu, harness, timing components and accessories. I lose the variable cam timing but I get to reuse all my custom swap bits, which saves a bunch of time I don't have before RRC22. But it requires some new custom parts. If one or more of our great fabricators has time and tools I'd love to First is the Throttle Body adapter. Replacing the factory e-gas with cable. I currenly have this partially drawn in CorelDraw and design is not absolute (still searching hardware). 96mm x 99mm. TB (red) bolts to piece_1 (blue) which bolts to piece_2 (green) which bolts to IM (yellow). (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1658826257.1.jpg) Second is cam gear adapters/spacers in steel. I need 2 @ 178* and 2 @ 180*. 4 total cuz 4 cams of fury. 6mm dowel pins look to be readily available. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1658826258.2.jpg) Third is a pair of aluminum block-off plates for the VVT cam adjusters. 1.5" x 3.5" Also drawn in CorelDraw, which can be exported as .ai or .dxf. Actually I might make these by hand. (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1658826258.3.jpg) Gratuitous PartsFinder pic (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1658826258.4.jpg) |
| Mueller |
Jul 26 2022, 07:59 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,157 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None
Hi Chris,
Remind me late next week if not in a huge hurry, I'm driving up to Cornelius Oregon for a wedding this weekend. That car is going to be even more wicked with that power upgrade! Think you'll do a VR30DDTT from a new Z or Infinity once they start to get wrecked on a more regular basis? |
Chris914n6 Project 914n6 -> the infamous Nissan V6 swap Jul 26 2022, 03:04 AM
tygaboy I may be able to assist with the block off plates.... Jul 26 2022, 07:49 AM
Chris914n6
Think you'll do a VR30DDTT from a new Z or In... Jul 30 2022, 02:49 PM
Chris914n6 Made it to the Gaudin Porsche Bumblebee reveal. Th... Jul 30 2022, 02:58 PM
Chris914n6 Let's file this under things I don't want ... Aug 9 2022, 03:59 PM
Mueller Looks easier than an Audi. Are upgraded guides ava... Aug 9 2022, 04:36 PM
Chris914n6 The factory fix is updated guides and chain. The c... Aug 10 2022, 07:57 PM
Chris914n6 Got behind on updates.
Boring part
<rant> ... Aug 14 2022, 02:25 PM
Chris914n6 I've gotten to the point where I have an engin... Aug 14 2022, 03:07 PM
Chris914n6 Not much for today. Got the vq30 stripped except f... Aug 16 2022, 12:17 AM
Mueller Hi Chris,
Just need to machine off the excess mat... Aug 21 2022, 10:12 PM
Chris914n6 :D :Qarl: :headbanger: :beer2:
Hi Chris,
J... Aug 22 2022, 08:45 PM
Chris914n6 Weekend update.
A little WD40 overnight soak and ... Aug 22 2022, 09:36 PM
Chris914n6 A rare moment of easier than expected.
The 3.5 Fl... Aug 24 2022, 10:40 AM
Chris914n6 Noting much to take pics of. Did some more cleanin... Aug 30 2022, 04:46 PM
Chris914n6 Another series of small accomplishments.
Used the... Sep 1 2022, 05:37 PM
tygaboy Chris - I'll get your parts shipped tomorrow. ... Sep 1 2022, 06:02 PM
Chris914n6 Those look goooood! :drooley:
Fun fact - y... Sep 2 2022, 02:30 PM
tygaboy
Fun fact - ... Sep 2 2022, 04:14 PM
Chris914n6 Another sleepy day of small projects.
The Pathy T... Sep 2 2022, 09:03 PM
Chris914n6 Well lookie here, I made #2 on Google :Qarl:
h... Sep 3 2022, 03:16 AM
Retroracer Using Eggo waffle packets to make bracket patterns... Sep 3 2022, 08:18 AM
Chris914n6 The acc cable bracket was a bit more involved desi... Sep 5 2022, 02:31 AM
Mueller These will ship out in the morning. Hope they work... Sep 6 2022, 12:41 AM
Chris914n6
These will ship out in the morning. Hope they wor... Sep 8 2022, 01:09 AM
Chris914n6 Today was Metal ---- in the mailbox :headbanger:... Sep 14 2022, 01:34 AM
Chris914n6 :shitfan: :shoot2kill: Andrew Wang
So the dude... Sep 14 2022, 02:14 AM
Chris914n6 The cam adapters seemed to be the easy method, but... Sep 14 2022, 03:16 AM
Mueller Awesome amount of work and very ingenious Chris. Sep 14 2022, 11:01 AM
Chris914n6 After RRC I wasn't in a hurry anymore... and I... Dec 3 2022, 01:10 AM
Chris914n6 So it started as a simple MIA (Mosquito Involved A... Apr 9 2023, 06:14 PM
Chris914n6 Three decisions were then made. One, I’d like to... Apr 9 2023, 06:14 PM
Chris914n6 An hour here, an hour there, I narrowed down the s... Apr 9 2023, 06:14 PM
Chris914n6 Continuing…
That’s a lot of work to be done, ... Apr 9 2023, 06:15 PM
FL000 Sounds like you are coming full circle and that’... Apr 9 2023, 06:48 PM
ClayPerrine I want to ask a curiosity question here.
Why use ... Apr 10 2023, 06:36 AM
Chris914n6
Why use... Apr 10 2023, 12:09 PM
ClayPerrine
Why us... Apr 10 2023, 12:39 PM
76-914 :blink: Apr 10 2023, 08:49 AM
tygaboy To @clayperrine Clay's question: Chris is ha... Apr 10 2023, 09:09 AM
ClayPerrine
Plus, I suspect Chris is a charter member of the ... Apr 10 2023, 09:26 AM
Chris914n6
To [b]@[url=http://www.914world.com/bbs2/index.p... Apr 10 2023, 12:19 PM
rick 918-S Just had to :bump: this. Oct 25 2024, 05:48 PM
76-914 Yeah, c'mon Chris. We want to see that thing m... Oct 28 2024, 08:14 AM
rick 918-S
Yeah, c'mon Chris. We want to see that thing ... Nov 30 2024, 07:03 AM
Chris914n6 Alright Alright Alright :)
Not much going on. ... Nov 30 2024, 05:38 PM
mgp4591
Not much going on.... Nov 30 2024, 11:56 PM
rick 918-S Been there with the back issues. I just had a inje... Nov 30 2024, 05:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 28th October 2026 - 12:15 AM |
