Attention Electrical Gurus, Need help with windshield washer wiring |
bbrock |
Jul 28 2022, 07:17 PM
Right after ordering a complete Car Magic kit to convert my windshield washer to electric, I read Sir Andy's excellent tech article on the conversion. The idea of pulling power for the washer pump off the intermittent wiper feed so the washer is activated by pulling back on the wiper lever was too elegant not to try.
I happened to have this nifty vintage VW style splitter I bought some time ago for not other reason than I thought it might come in handy for some future custom wiring project. It was just the ticket for splitting off of my intermittent washer relay to power the washer pump. After hooking everything up, I pulled back on the wiper lever and HUZZAH! The washers squirted and the wipers ran for two sweeps and parked. Pretty slick! I couldn't understand how the intermittent wipers would work when the lever was pulled down to turn the intermittent wipers on. I pull down on the lever to test them and nothing. As soon as I unplug the washer pump, the intermittent wipers start running. I'm not sure how the intermittent relay works, but thinking the timer is from charging a capacitor which then "bump starts" the wipers to run a single cycle. Is there is a reasonably simple way to isolate the pump so it allows the intermittent mechanism to run without activating the washer pump? Could be a fun project. Or should I just go back to the original plan of installing the Car Magic switch? I just like the idea of minimizing the wiring. |
Superhawk996 |
Jul 30 2022, 10:36 AM
914 Guru Group: Members Posts: 5,915 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
I apologize I'm worthless for this thread. All my books, schematics and parts are packed up and are not at hand to analyze or test.
Looks like you're getting closer to solving this. Hope this doesn't end up needing an Arduino! (IMG:style_emoticons/default/happy11.gif) |
bbrock |
Jul 30 2022, 11:20 AM
I apologize I'm worthless for this thread. All my books, schematics and parts are packed up and are not at hand to analyze or test. Looks like you're getting closer to solving this. Hope this doesn't end up needing an Arduino! (IMG:style_emoticons/default/happy11.gif) Ha ha. Funny because I think doing this via arduino would be fairly simple, but overkill. |
Superhawk996 |
Jul 30 2022, 11:38 AM
I apologize I'm worthless for this thread. All my books, schematics and parts are packed up and are not at hand to analyze or test. Looks like you're getting closer to solving this. Hope this doesn't end up needing an Arduino! (IMG:style_emoticons/default/happy11.gif) Ha ha. Funny because I think doing this via arduino would be fairly simple, but overkill. Can you post a more comprehensive circuit diagram of how you have this wired and what you believe the circuits to be? I'm wondering if you can utilize the standard Bosch relay with one normally open contact and one normally closed contact to do what you want. I'm thinking you probably need two relays cascaded and/or may need a diode on one of them to prevent the ground from reaching the intermittent relay when one of the relays are activated. Sometimes when I'm forced to draw the circuit, I'll either realize that I don't understand it as I thought I did from the schematic, or the solution becomes obvious. |
bbrock |
Jul 30 2022, 12:41 PM
Can you post a more comprehensive circuit diagram of how you have this wired and what you believe the circuits to be? I'm wondering if you can utilize the standard Bosch relay with one normally open contact and one normally closed contact to do what you want. I'm thinking you probably need two relays cascaded and/or may need a diode on one of them to prevent the ground from reaching the intermittent relay when one of the relays are activated. Sometimes when I'm forced to draw the circuit, I'll either realize that I don't understand it as I thought I did from the schematic, or the solution becomes obvious. The circuit is so simple there is really no need for a diagram. See the pic in my first post of the 3-way connector? One of those wires in is the original brown/blk (S1) wire from the circuit that is supposed to go into the relay socket. One wire coming out now goes to the relay socket to complete the original circuit. The other wire coming out goes to the (+) on the washer pump. The washer pump is grounded to chassis through its mounting screw. That's it and the simplicity is why I want to make this work. Quite simply, I need a switch on the wire between the 3-way and pump that is closed when there is 12v on that wire, and open the rest of the time. Digging around, it looks like I need a low voltage disconnect. Thinking something like this might work. Wonder if anyone with more electronic smarts could confirm. Now that I know leaving the washer pump connected isn't going to fry the intermittent circuit, I'm leaving it connected for now as I need the washer pump more than the intermittent. I'm optimistic this one-wire, no switch modification solution could work. (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 15th June 2024 - 12:56 PM |
