| Big Len |
Jul 29 2022, 02:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,787 Joined: 16-July 13 From: Edgewood, New Mexico Member No.: 16,126 Region Association: Southwest Region |
| Superhawk996 |
Jul 30 2022, 02:59 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,903 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Very nice car that anyone could be proud to own. However, I'm not buying that it's only 27K miles. Seems to me that folks are taking advantage of the 5 digit ODO way too often. Pedal pads seem to have some significant wear on them for 27K. I think there is too much rust and road debris abrasion on the bottom side to be 27K. I bought my Miata used with 30K+ miles on it and it had far less road blast / abrasion on bottom side than this car has. I could be wrong but I'm a doubting Thomas by nature. |
| wonkipop |
Jul 30 2022, 06:52 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,566 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille
(IMG:style_emoticons/default/agree.gif) Very nice car that anyone could be proud to own. However, I'm not buying that it's only 27K miles. Seems to me that folks are taking advantage of the 5 digit ODO way too often. Pedal pads seem to have some significant wear on them for 27K. I think there is too much rust and road debris abrasion on the bottom side to be 27K. I bought my Miata used with 30K+ miles on it and it had far less road blast / abrasion on bottom side than this car has. I could be wrong but I'm a doubting Thomas by nature. its a strange one. had a good look at photos while i was adding data to L Jet research we have been doing. more careful look at the oil change sticker on the door reveal. 8/77 - 20,010m. the car was sold new 9/74. original owner was doing 7,000m a year at that point. if that mileage kept up until 1985 the car would be approx a 70-75.000 m car. to be a 29 K m car the driving pattern by the owner must have changed drastically before it was stored away in 85. that is possible. or it could be a broken odo car. (but still sub 100K miles). wherever it has sat stored has been very humid. the surface corrosion on all the plated engine parts/bolts is not something i would expect on a dry stored car. (see the AFM to aircleaner bolts and other engine fittings). mine is not corroded like that and neither are several members cars here that have been well looked after. all those bolts plates etc in and on engines look better than that. the condition of the tool kit is surprising. lots of surface rust on jack. (missing plastic bag). original may have been lost and its a replacement? other strange things are drive shafts still have white painted stamped numbers on them. (i didn't know about those numbers on driveshafts until i saw these photos, long gone on mine). those driveshafts have not seen over 100K miles. much less. it could be a very good car but one i would want to take a close look at in person given the battery tray work and some other clues. i can remember looking at cars in 89 that had shot hell holes even then, but cosmetically were still very good otherwise. i'd like to know more about the engine and just how it was stored. and recommissioned. 30+ years is a long time to be doing the woody allen trick with the VW in a cave. but it can be done. if the engine was stored right. topped right up with fresh oil before storage. i did it, but only for 16 years. (IMG:style_emoticons/default/blink.gif) EDIT its also got a strange engine bay back pad. they should be grey if stock and unmeddled with. that one looks like its been pulled out and shot with some kind of black ripple finish paint. someone's been in that engine bay and done a big clean up/dress up. dunno why you would change the back pad on a 29K mile car? |
| Superhawk996 |
Jul 31 2022, 09:43 AM
other strange things are drive shafts still have white painted stamped numbers on them. (i didn't know about those numbers on driveshafts until i saw these photos, long gone on mine). those driveshafts have not seen over 100K miles. much less. I'd disagree on the 1/2 shafts. Those shafts have some serious mileage on them given the amount of build up on oil dust build up on the boots, oil leakage around the trans, etc. Looks to me like the driver side shaft was disconnected at the trans and then vehicle rolled around tearing up the the paint on the shaft as the CV shaft hit the trailing arm. A nick in the paint from road debris or paint flaw doesn't lead to a rust ring like that. This sort of stuff just isn't consistent with 28K original miles or even having sat for 30 years. I bought a set of used 914/6 shafts and CV's not long ago, they weren't advertised as sub 27K miles and they were in far better shape than these are. Hopefully someone buys at the right price and doesn't buy into the 28K mile hype which for me, means I can't trust anything the seller has to say. This whole BAT "shows 28k miles" stuff is (IMG:style_emoticons/default/stromberg.gif) knowing full well that they haven't lied to a degree that can be contested in a court of law but knowing full well that the car really isn't a 28K original miles but is really 128K. The rest of the car speaks for itself and anyone should be proud of a car like that even if it has 128K miles. But lets stop the nonsense of pretending that cars like these are low mileage. If the mileage was documented from day one and consistent to 2022, that would be one thing. That is not what is being offered here. ![]() |
Big Len 27,000 mile original '74 on BaT Jul 29 2022, 02:38 PM
SKL1 Will be interesting to watch. But those wiper bla... Jul 29 2022, 02:50 PM
dr914@autoatlanta.com certainly a bit rough for only 27 thousand miles, ... Jul 29 2022, 02:58 PM
StarBear
I'm going for it, $71K.
https://bringat... Jul 29 2022, 04:48 PM
Big Len
[quote name='Big Len' post='3019017' date='Jul 29... Jul 29 2022, 05:11 PM
Cairo94507 I agree with the Doc on this one. I expected it t... Jul 29 2022, 05:31 PM
Van B Calling @wonkipop ! This ole girl had to be... Jul 29 2022, 06:50 PM
wonkipop
Calling [b]@[url=http://www.914world.com/bbs2/in... Jul 29 2022, 07:57 PM
wonkipop
https://bringat... Jul 29 2022, 07:46 PM
Jett Love the color, but there are areas that look grea... Jul 30 2022, 02:19 PM
wonkipop
other strange things are drive shafts still hav... Jul 31 2022, 05:02 PM
wonkipop @Big Len
i'm putting my bet in at $50K ... Jul 30 2022, 08:03 PM
Van B @Superhawk996 and I are of the same mind on this ... Jul 30 2022, 08:10 PM
wonkipop
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jul 30 2022, 10:59 PM
914Next Yeah I am intrigued with this one also. I was the... Jul 31 2022, 07:38 AM
Big Len @wonkipop Yes, I saw the engine bar painted black... Jul 31 2022, 08:12 AM
wonkipop
@[url=http://www.914world.com/bbs2/index.php?show... Jul 31 2022, 08:28 AM
Superhawk996
its a good car in a lot of respects, but it ain... Jul 31 2022, 09:55 AM
Jett The pic 66 shows that this car has some rust tryin... Jul 31 2022, 08:13 AM
FlacaProductions This may be the previous listing:
http://classicc... Jul 31 2022, 09:56 AM
Superhawk996
http://classic... Jul 31 2022, 10:03 AM
914Next
http://classic... Jul 31 2022, 04:23 PM
wonkipop
http://classic... Jul 31 2022, 05:43 PM
Van B @wonkipop I definitely thing you’re spot on wit... Jul 31 2022, 11:12 AM
wonkipop
[b]@[url=http://www.914world.com/bbs2/index.php?s... Jul 31 2022, 06:24 PM
FlacaProductions Searching the VIN is how I found the previous list... Jul 31 2022, 04:39 PM
wonkipop i'm going for broken odo.
here is the mileage... Jul 31 2022, 09:10 PM
Lockwodo
https://bringat... Jul 31 2022, 09:43 PM
wonkipop
[url=https://b... Jul 31 2022, 10:02 PM
Superhawk996
[quote name='Big Len' post='3019017' date='Jul 29... Aug 1 2022, 05:48 AM
wonkipop
[quote name='Lockwodo' post='3019597' date='Jul 3... Aug 1 2022, 06:06 PM
Superhawk996
if you have certifiable 27,000 m car not merely a... Aug 2 2022, 07:28 AM
windforfun Just another horse trader. At least with a horse ... Jul 31 2022, 09:50 PM
wonkipop
Just another horse trader. At least with a horse... Jul 31 2022, 10:11 PM
930cabman Possible but not probable.
As always: buyer bewar... Aug 1 2022, 06:27 PM
wonkipop another web entry on it from 19.
scroll down comme... Aug 1 2022, 09:26 PM
Van B Whoever “Oldalfapvguy” is must not be reading ... Aug 1 2022, 10:12 PM
wonkipop
Whoever “Oldalfapvguy” is must not be reading... Aug 2 2022, 01:28 AM
wonkipop @Van B
i better be nice re ye olde romeo dude ins... Aug 2 2022, 02:12 AM
gandalf_025 Mine has been parked since 1988...
I know the mil... Aug 2 2022, 06:00 AM
Big Len Guys, do you have any clue what the costs are to b... Aug 2 2022, 10:28 AM
Superhawk996
Guys, do you have any clue what the costs are to ... Aug 2 2022, 11:10 AM
wonkipop
Guys, do you have any clue what the costs are to... Aug 2 2022, 06:02 PM
wonkipop
Guys, do you have any clue what the costs are to ... Aug 2 2022, 05:39 PM
Van B I’m thinking about flipping a 29k mile car… I ... Aug 2 2022, 08:54 PM
wonkipop
I’m thinking about flipping a 29k mile car… I... Aug 3 2022, 02:07 AM
r_towle One winter or two in the northeast can create a to... Aug 3 2022, 06:47 AM
One winter or two in the northeast can create a t... Aug 3 2022, 06:58 AM
wonkipop
One winter or two in the northeast can create a ... Aug 3 2022, 07:36 AM
StarBear My car “shows” nearly 20k miles - but I have t... Aug 3 2022, 07:32 AM
Superhawk996
My car “shows” nearly 20k miles - but I have ... Aug 3 2022, 09:34 AM
My car “shows” nearly 20k miles - but I have... Aug 3 2022, 09:43 AM
bbrock
I'm the same way with numbers matching and da... Aug 3 2022, 07:04 PM
930cabman
I'm the same way with numbers matching and d... Aug 5 2022, 09:34 AM
Jett
My car “shows” nearly 20k miles - but I have... Aug 4 2022, 08:41 AM
dr914@autoatlanta.com I had a paper weight in my garage years ago, that ... Aug 4 2022, 09:41 AM
Superhawk996
I will have it until I die, and the day after my ... Aug 4 2022, 11:50 AM
930cabman
I will have it until I die, and the day after my... Aug 4 2022, 03:39 PM
Big Len Not that my opinion matters much, but do I think t... Aug 3 2022, 09:33 AM
wonkipop
Not that my opinion matters much, but do I think ... Aug 3 2022, 05:43 PM
dr914@autoatlanta.com I certainly believe the miles, just has had a hard... Aug 3 2022, 10:04 AM
I certainly believe the miles, just has had a har... Aug 3 2022, 10:15 AM
wonkipop
I certainly believe the miles, just has had a har... Aug 5 2022, 03:39 AM
Superhawk996 Not buying the miles at all.
Too much road grim... Aug 3 2022, 12:04 PM
wonkipop PS @Big Len .
have you seen the rolling assembly... Aug 3 2022, 05:58 PM
Big Len Excellent discussion with differing opinions.
My ... Aug 4 2022, 06:54 AM
Superhawk996
My... Aug 4 2022, 07:24 AM
Jett
M... Aug 4 2022, 08:28 AM
wonkipop
My... Aug 4 2022, 03:57 PM
EdwardBlume I’ll make a guess on the price tomorrow or so.
Big Len @wonkipop - An interesting point no doubt. That M... Aug 5 2022, 06:03 AM
wonkipop
[b]@[url=http://www.914world.com/bbs2/index.php?s... Aug 5 2022, 06:35 AM
Big Len I don't know why I so fascinated with this sal... Aug 5 2022, 07:01 AM
bbrock
I don't know why I so fascinated with this sa... Aug 5 2022, 07:58 AM
wonkipop
I don't know why I so fascinated with this s... Aug 5 2022, 06:22 PM
Jett [quote name='Big Len' date='Aug 5 2022... Aug 5 2022, 08:15 AM
DRPHIL914
[quote name='Big Len' date='Aug 5 202... Aug 5 2022, 10:15 AM
Superhawk996 The fat lady has sung.
Good price for a very... Aug 5 2022, 11:29 AM
mepstein Much more realistic price than the last couple sal... Aug 5 2022, 11:38 AM
914sgofast2 I don't remember the Seller of this car ever m... Aug 5 2022, 12:45 PM
Big Len My guestimate was only off by a little bit :lol4:... Aug 5 2022, 01:31 PM
wonkipop
My guestimate was only off by a little bit :lol4... Aug 5 2022, 05:03 PM
FlacaProductions ok - should we talk about the '70 6, now?
http... Aug 5 2022, 01:57 PM
Jett
htt... Aug 5 2022, 08:07 PM
gereed75 Thats a beaut Clark. Very nice example. Not nitpi... Aug 5 2022, 03:25 PM
mepstein Back in 2006/2007, every house was going for top d... Aug 5 2022, 03:39 PM
porschetub
Back in 2006/2007, every house was going for top ... Aug 5 2022, 05:14 PM
914sgofast2
Back in 2006/2007, every house was going for top... Aug 5 2022, 05:16 PM![]() ![]() |
Lo-Fi Version | Time is now: 19th June 2026 - 12:19 AM |
