Help me help you Seal fitment, Started a new thread to deconstruct this |
Mikey914 |
Aug 10 2022, 04:50 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This was brought us as an issue and I'm really trying to figure this out. Any ideas of why the window would look lower and have a gap here.
Here were my thoughts - I keep looking at this and something doesn't look right. Given that the blocks are identical to the factory ones in shape and durometer, what would the solution be here? There appears to be a 1/2" section of rubber not fully seated, Is it holding it out? Could the amount of butyl behind the "chrome" be holding it down slightly? I don't think that would be the whole story. The triangle window looks like the top is seated deeper than the cap. Almost like if the top of the triangle window was shimmed out more it would push the bottom of the cap out more to "close the gap". This appears to be where the failure is - at least in my eyes. I've seen many of the caps worn and look slightly deformed from the top of the glass pushing it out, but not here. It looks like it's barely engaged. Why it would sit lower is beyond me. The initial complaint was it was too tight, which would hold it up. Submitted to the brain trust Attached thumbnail(s) |
Chris914n6 |
Aug 10 2022, 08:04 PM
Jackstands are my life. Group: Members Posts: 3,328 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Funny I just looked into this this morning.
Short answer... top of the glass channel needs to be moved forward til the rear edge aligns with the rear point of the frame seal molding. It's not the seal, it's the alignment of the glass channel. |
Mikey914 |
Aug 11 2022, 03:21 PM
Funny I just looked into this this morning. Short answer... top of the glass channel needs to be moved forward til the rear edge aligns with the rear point of the frame seal molding. It's not the seal, it's the alignment of the glass channel. This is what I was asking. My cars the old cap is actually deformed from holding the glass on, where it looks like this one is a bit short. My experience with these cars is that it's not always as it appears. Sometimes a little change can affect other parts in ways that are not apparent. There does seem to be a theme. So we will need to do a video of how we install and adjust to fit. I will begin this this next week. |
Lo-Fi Version | Time is now: 1st June 2024 - 06:33 AM |
