Help me help you Seal fitment, Started a new thread to deconstruct this |
Mikey914 |
Aug 10 2022, 04:50 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This was brought us as an issue and I'm really trying to figure this out. Any ideas of why the window would look lower and have a gap here.
Here were my thoughts - I keep looking at this and something doesn't look right. Given that the blocks are identical to the factory ones in shape and durometer, what would the solution be here? There appears to be a 1/2" section of rubber not fully seated, Is it holding it out? Could the amount of butyl behind the "chrome" be holding it down slightly? I don't think that would be the whole story. The triangle window looks like the top is seated deeper than the cap. Almost like if the top of the triangle window was shimmed out more it would push the bottom of the cap out more to "close the gap". This appears to be where the failure is - at least in my eyes. I've seen many of the caps worn and look slightly deformed from the top of the glass pushing it out, but not here. It looks like it's barely engaged. Why it would sit lower is beyond me. The initial complaint was it was too tight, which would hold it up. Submitted to the brain trust Attached thumbnail(s) |
wonkipop |
Aug 12 2022, 08:18 PM
Advanced Member Group: Members Posts: 4,398 Joined: 6-May 20 From: north antarctica Member No.: 24,231 Region Association: NineFourteenerVille |
@Mikey914
that second image of faded red car looks pretty much exactly the same as mine. in terms of the rear of the triangle post cap and the windscreen frame and chrome trim. nothings easy with this sort of stuff. so much of it is down to the nature of the original materials themselves. i'll bet this beautiful little detail gave VW and porsche a headache at the time getting it just right. especially in terms of not having to do too much fiddling on the assembly line. |
Lo-Fi Version | Time is now: 6th June 2024 - 10:43 PM |
