Rear Alignment: Relationship between Camber and Toe, Talking through my settings, interested in informed feedback! |
Morrie |
Aug 13 2022, 01:46 PM
Member Group: Members Posts: 181 Joined: 8-October 07 From: Cedar Park, Texas Member No.: 8,198 Region Association: Southwest Region |
Hi Guys!
I had my car 4 wheel aligned yesterday and overall went well. I've replaced all the bushings, shocks, struts, springs, bearings, etc so it was all totally out of wack.... Good news, everything came into spec in front. All good. Car drives great now. In the rear I needed a bit of camber to clear the tops of my tires, so I am sitting here: Rear Left: Camber: -1 deg 24' Rear Right: Camber: -1 deg 12' Camber: Factory says max difference from left to right is +/- 20'. I've got 12' difference side to side so I think I am okay there, even though the extra camber may cause some tire wear that I can live with. Toe: Factory says toe should be 0deg +15' per side. The alignment shop set limits to 0deg +/- 15'. A lot of numbers and I can make a bunch of guesses, but I would like to know for my road car which gets some spirited hill country driving, should I work on getting more positive rear Sorry if this is beaten to death or overcomplicated. Writing it down here helped me get it straight in my head. (IMG:style_emoticons/default/blink.gif) If it helps, below are my suspension settings and condition. Car was corner balanced prior to going for alignment, and is slightly lowered. Clearance on the RH side (passengers) rear tire is tight but it does clear with the current settings. Front: Stock Torsion Bars Rear: New 100lb Eibach coils Thanks Guys! |
mlindner |
Aug 14 2022, 10:18 AM
Senior Member Group: Members Posts: 1,526 Joined: 11-November 11 From: Merrimac, WI Member No.: 13,770 Region Association: Upper MidWest |
I agree 100% with Superhawk996, you need to find the problem and have it fixed. Just FYI, my car was a complete rebuild, cleaned and spec'ed or replaced parts. Thats why I felt comfortable with the long-gated holes in order to achieve toe in. And thanks Chris for your comment regarding stiffening kit....that explain that. Mark
Lo-Fi Version | Time is now: 2nd June 2024 - 09:22 AM |
