Help me help you Seal fitment, Started a new thread to deconstruct this |
Mikey914 |
Aug 10 2022, 04:50 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
This was brought us as an issue and I'm really trying to figure this out. Any ideas of why the window would look lower and have a gap here.
Here were my thoughts - I keep looking at this and something doesn't look right. Given that the blocks are identical to the factory ones in shape and durometer, what would the solution be here? There appears to be a 1/2" section of rubber not fully seated, Is it holding it out? Could the amount of butyl behind the "chrome" be holding it down slightly? I don't think that would be the whole story. The triangle window looks like the top is seated deeper than the cap. Almost like if the top of the triangle window was shimmed out more it would push the bottom of the cap out more to "close the gap". This appears to be where the failure is - at least in my eyes. I've seen many of the caps worn and look slightly deformed from the top of the glass pushing it out, but not here. It looks like it's barely engaged. Why it would sit lower is beyond me. The initial complaint was it was too tight, which would hold it up. Submitted to the brain trust Attached thumbnail(s) |
Mikey914 |
Aug 16 2022, 12:21 PM
Honestly the door changes were the only Real changes made. Consistung og of the vertical track roller to fuzzies, the aluminum to accomidate the smaller end caps, and the outer scraper seal profile. Lastly the aluminium on the pillar. The tabs were made slightly shorter.
There were the major changes that affect Tor are adjacent this seal. After studying many fallen seals the later versión doesn’t come apart in the corners, This is why we went this direction. There are tradeoffs but following factory on this one. The earlier ones we made were Like the early. They were harder to bond also. |
Lo-Fi Version | Time is now: 6th June 2024 - 06:07 PM |
