Transaxle final drive |
partwerks |
Aug 20 2022, 07:16 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
If putting in a trans and different final drives, like 3.70, 3.90, 4.11 for example.
How do you know what the engine rpm is running at, for like 60 mph? Can a later Subaru Forrester, with a final drive be changed out to a taller gear, like 3.70 for example, instead of a 4.11? Looks like the WRX are higher priced than the Forrester trans. |
DahlbergDiver |
Aug 20 2022, 08:05 PM
Newbie Group: Members Posts: 10 Joined: 15-December 21 From: Michigan Member No.: 26,170 Region Association: Upper MidWest |
To find a gear ratio to mph calculator, google that phrase and you'll find a ton of them. Here's one: https://purperformance.com/p-29669-rpm-calculator.html
For the Suby trans ratios, I think I can help you out a bit. I just bought a trans from a 2016 Forester from the local junkyard for $300. The WRX trannies are just too costly, even though they have a more desirable final drive. But, if you are cruising down the road at 55mph on stock tires, the difference between the two transmissions is only 250rpm. I decided that spending the extra money for the WRX trans was not worth a 250rpm difference. So I decided to just run a little bit taller tires in the back to help bring cruising rpm down a bit. Here's the specs from my research: 2016 Forester: Final Drive 4.444, 6th gear .695 Rpm at 55mph: 2250 2016 WRX: Final drive: 4.111, 6th gear .666 Rpm at 55mph: 2000 These calculations are made using 25.3" tire diameter. (I believe that's stock) Hope this helps. I only have data for 6th gear, because I was only concerned with cruising rpm when i researched this. I also looked into getting the gear ratio changed in the Forester trans, but couldn't find anything by web searching. Maybe a trans expert can chime in, but I think that if you got a WRX ring and pinion from eBay, you could put it in the Forester trans. Would be cheaper than buying the whole WRX gearbox. Just a theory. I personally am going with the stock forester trans and taller tires. IMO not worth fooling around with changing final drive unless you desperately wanna bring down the rpm. |
partwerks |
Aug 20 2022, 08:33 PM
To find a gear ratio to mph calculator, google that phrase and you'll find a ton of them. Here's one: https://purperformance.com/p-29669-rpm-calculator.html For the Suby trans ratios, I think I can help you out a bit. I just bought a trans from a 2016 Forester from the local junkyard for $300. The WRX trannies are just too costly, even though they have a more desirable final drive. But, if you are cruising down the road at 55mph on stock tires, the difference between the two transmissions is only 250rpm. I decided that spending the extra money for the WRX trans was not worth a 250rpm difference. So I decided to just run a little bit taller tires in the back to help bring cruising rpm down a bit. Here's the specs from my research: 2016 Forester: Final Drive 4.444, 6th gear .695 Rpm at 55mph: 2250 2016 WRX: Final drive: 4.111, 6th gear .666 Rpm at 55mph: 2000 These calculations are made using 25.3" tire diameter. (I believe that's stock) Hope this helps. I only have data for 6th gear, because I was only concerned with cruising rpm when i researched this. I also looked into getting the gear ratio changed in the Forester trans, but couldn't find anything by web searching. Maybe a trans expert can chime in, but I think that if you got a WRX ring and pinion from eBay, you could put it in the Forester trans. Would be cheaper than buying the whole WRX gearbox. Just a theory. I personally am going with the stock forester trans and taller tires. IMO not worth fooling around with changing final drive unless you desperately wanna bring down the rpm. Tire size I have: https://tiresize.com/tiresizes/225-50R16.htm |
Lo-Fi Version | Time is now: 7th June 2024 - 07:13 AM |
