> Do Type I oil pumps work correctly in Type IV's ?
Mueller
post May 29 2003, 02:20 PM
914 Freak!
For Form, Fit and Function, are these interchangeable?
Thanks
bander
post May 30 2003, 06:36 AM
The cover needs to have a corner choped off to clear the motor mount. After doing this, the cover was warped by about .010". I was thinking about welding a 1/2" slice of a 2" pipe to the cover to stiffen it, but didn't. I Flycut it to flatten it.
Also, I have a Web cam with 5 screws. the heads of the scews were cut down to clear the FIXED pin on the pump. On the first attempt, one screw hit the pump every time around and may have been a contributor to my needing to tear it down after 500 miles. Grind that down as needed.
- Lo-Fi Version Time is now: 2nd April 2026 - 04:13 PM
