> While the Engine is Out, Things you'll regret overlooking if you don't address them while the engine is out of the car.
DennisV
post Aug 24 2022, 07:22 AM
I did some poking on the forum, but didn’t find a definitive “while the engine is out” thread, other than this thread by TRS63. Which seemed somewhat specific to his car. Are there some general recommendations for what should be addressed while you have improved accessibility? Would it be helpful to consolidate a list and add it to the Lapuwali Classic Thread Forum?
In our case, we have a 1970 914-6. The engine and transmission will both be rebuilt. So those are their own projects. The chassis is in quite good shape in terms of very little rust. It has 93k miles on the odometer and has sat without moving for about 15 years.
Our priorities are safety, reliability, and originality. The list I’ve started compiling, mostly from reading books, includes the following. Roughly in priority order, in consideration of time and budget:
  1. Fuel line secure and protect per recall 9J
  2. Fuel line replace cloth with rubber - replace
  3. Engine mount - replace
  4. Transmission mounts - replace
  5. Clutch, pressure plate, flywheel - replace
  6. Clutch cable - replace
  7. Fuel pump relocation related to TSB P213 on vapor lock
  8. Voltage plate cover per recall 9K
  9. Rear wheel bearings
  10. CDI- refurb
  11. Shocks - eval?
  12. CV joint gaskets - replace
  13. Fuel pump - eval?
  14. Ball joints - eval?
  15. Tie rod ends - eval?
  16. Heater hoses - eval?
  17. Brake pads - replace
  18. Brake rotors - eval?
  19. Brake caliper - eval?
I put brakes at the bottom, as I don’t think it matters much if the engine is out in terms of access.
What am I missing that I will regret later if I don’t address it now? Some of these I don’t know if evaluating for reuse should even be a consideration, given how long the car has sat.
Let’s “just rebuild the engine” and get it on the road has become quite a project! My goal is to get this done in time to drive it to Parade in Palm Springs 2023. Stretch goal would be to make it to the LA literature show.
Thanks for sharing your experience.
VaccaRabite
post Aug 24 2022, 09:19 AM
En Garde!
Going to echo what others have been saying. Trash those plastic fuel lines in the tunnel with stainless. Car fires suck.
Zach
DennisV   While the Engine is Out   Aug 24 2022, 07:22 AM
DennisV   As it sits...   Aug 24 2022, 07:25 AM
914e   Brake hoses. I had all four burst at the same time...   Aug 24 2022, 07:53 AM
DennisV   I would replace the plastic fuel line in the tunn...   Aug 24 2022, 11:24 AM
Geezer914   Rust spots, touch up paint, engine bay seals, stai...   Aug 24 2022, 08:22 AM
Geezer914   Rust spots touch up paint, (I painted my engine ba...   Aug 24 2022, 08:31 AM
brant   Rust spots touch up paint, (I painted my engine b...   Aug 24 2022, 09:00 AM
ClayPerrine   Change the alternator/fan belt. Adjust the valves...   Aug 24 2022, 08:36 AM
willieg   I do not have an original 914 (Subie powered) so w...   Aug 24 2022, 08:43 AM
Cairo94507   Check to make sure the clutch cable tube is secure...   Aug 24 2022, 08:57 AM
VaccaRabite   Going to echo what others have been saying. Trash...   Aug 24 2022, 09:19 AM
ThePaintedMan   In terms must for ANY car, but especially when the...   Aug 24 2022, 09:49 AM
barefoot   Replace the plastic bushings on those rear sway ba...   Aug 24 2022, 11:35 AM
JamesJ   Replace speedometer cable if necessary   Aug 24 2022, 03:40 PM
914SIXXation   Replace speedometer cable if necessary GREAT li...   Aug 24 2022, 04:26 PM
bkrantz   If in any doubt, replace or rebuild the brake pres...   Aug 24 2022, 07:27 PM
DennisV   If in any doubt, replace or rebuild the brake pre...   Aug 25 2022, 08:30 PM
DC_neun_vierzehn   This is helpful as I have my motor and trans out (...   Aug 24 2022, 09:11 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:07 AM
