Removing TPS - does the throttle body have to come off?, or can i just pull it off the shaft? |
FlacaProductions |
Aug 23 2022, 07:09 PM
Senior Member Group: Members Posts: 1,615 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
I have a little stumble/hesitation right around 3k cruising. All else is good. Unplugged the TPS and the stumble goes away. It's pretty clear.
Looking to do a quick clean until i have time and can get a replacement board here. Can I just take the connector and two mounting screws off the side of the TPS and pull it off the shaft without having to remove the air cleaner housing and throttle body, etc? |
FlacaProductions |
Aug 24 2022, 06:59 AM
I think I'll try it without pulling the TB first - messes with less, overall.
Lockwodo |
Aug 24 2022, 10:12 AM
Member Group: Members Posts: 201 Joined: 23-December 21 From: Santa Cruz, Californnia Member No.: 26,193 Region Association: Northern California |
I think I'll try it without pulling the TB first - messes with less, overall. A pair of ohm meter test leads with micro alligator clips will help for the calibration step. The TPS pins will be facing downwards but with a mirror you'll be able to connect the leads to the right pins. |
Lo-Fi Version | Time is now: 7th June 2024 - 05:18 AM |
