| DennisV |
Aug 24 2022, 07:22 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 886 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
I did some poking on the forum, but didn’t find a definitive “while the engine is out” thread, other than this thread by TRS63. Which seemed somewhat specific to his car. Are there some general recommendations for what should be addressed while you have improved accessibility? Would it be helpful to consolidate a list and add it to the Lapuwali Classic Thread Forum?
In our case, we have a 1970 914-6. The engine and transmission will both be rebuilt. So those are their own projects. The chassis is in quite good shape in terms of very little rust. It has 93k miles on the odometer and has sat without moving for about 15 years. Our priorities are safety, reliability, and originality. The list I’ve started compiling, mostly from reading books, includes the following. Roughly in priority order, in consideration of time and budget:
What am I missing that I will regret later if I don’t address it now? Some of these I don’t know if evaluating for reuse should even be a consideration, given how long the car has sat. Let’s “just rebuild the engine” and get it on the road has become quite a project! My goal is to get this done in time to drive it to Parade in Palm Springs 2023. Stretch goal would be to make it to the LA literature show. Thanks for sharing your experience. |
| bkrantz |
Aug 24 2022, 07:27 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,646 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
If in any doubt, replace or rebuild the brake pressure relief valve. This thing is nearly impossible to change out with the engine installed.
| DennisV |
Aug 25 2022, 08:30 PM
If in any doubt, replace or rebuild the brake pressure relief valve. This thing is nearly impossible to change out with the engine installed. @bkrantz Is there a way to test it? The car has sat for roughly 15 years without moving. I have no idea if it worked when it was parked. I guess that qualifies as doubt, and you're suggesting we should rebuild it. I now see this is covered to some degree in the 914-6 Porsche Factory Manual: brake section Removing and Installing Brake Pressure Regulator page 3.3-1/1. I'll look harder next time before I post a question. Thanks for the suggestion. |
DennisV While the Engine is Out Aug 24 2022, 07:22 AM
DennisV As it sits...
Aug 24 2022, 07:25 AM
914e Brake hoses. I had all four burst at the same time... Aug 24 2022, 07:53 AM
DennisV
I would replace the plastic fuel line in the tunn... Aug 24 2022, 11:24 AM
Geezer914 Rust spots, touch up paint, engine bay seals, stai... Aug 24 2022, 08:22 AM
touch up paint, (I painted my engine ba... Aug 24 2022, 08:31 AM
brant
Rust spots
touch up paint, (I painted my engine b... Aug 24 2022, 09:00 AM
ClayPerrine Change the alternator/fan belt.
Adjust the valves... Aug 24 2022, 08:36 AM
willieg I do not have an original 914 (Subie powered) so w... Aug 24 2022, 08:43 AM
Cairo94507 Check to make sure the clutch cable tube is secure... Aug 24 2022, 08:57 AM
VaccaRabite Going to echo what others have been saying. Trash... Aug 24 2022, 09:19 AM
ThePaintedMan In terms must for ANY car, but especially when the... Aug 24 2022, 09:49 AM
barefoot Replace the plastic bushings on those rear sway ba... Aug 24 2022, 11:35 AM
JamesJ Replace speedometer cable if necessary Aug 24 2022, 03:40 PM
914SIXXation
GREAT li... Aug 24 2022, 04:26 PM
DC_neun_vierzehn This is helpful as I have my motor and trans out (... Aug 24 2022, 09:11 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:35 AM |
