> 1975 Wiring Harness repair - fix or delete seat sensor wiring
DaveB
post Jun 1 2022, 11:57 AM
I just removed the wiring harness from my '75. I am not sure what the PO did or what happened but there are a lot of shorts with melted and exposed wiring. The seat wiring is melted into a large uniform mess.
I hate any form of lock out with seat belts. Can I remove the wiring and sensors or is there any reason I should restore the wiring under the seats and then make the modification to delete the lock out and fasten seat belt signals? I can't imagine a future owner thinking they would want to have the wiring available to connect a starter lock out to the seat belts.
Thanks,
DaveB
JeffBowlsby
post Aug 29 2022, 06:00 PM
was there a formal campaign to fix the interlock system? Code?
Is there a list of items for the fix?
--> Not to my knowledge. Only a guess but someone a long time ago seems to have figured out that the logic box simply interrupts ignition power and that the two big yellow wires carried that current. Connect them together and voila! Bypassed.
Just wonder because the Current flow diagram in the Technical manual does not show the second relay, and the wiring connections are so different. However, it seems to me that a recall could have meant adding the second relay, and rerouting some of the wires as well as bridging the yellow power wires. I see one wire coming from a sleeved bundle to the seatbelts that is brown with a .110 terminal on it and a second wire heading up to the interior light. This terminal looks like it should go to terminal 31, but a short ground wire to a tab below the sockets is fitted there, and there is no other place I can see where this loose terminal should go. It is in three or 4 harnesses I am looking at.
Dave
--> Thats interesting, had no known that before. What are the two relays? Under the pass seat there is a seatbelt interlock logic box and the door open/fasten seatbelt buzzer. Neither are relays, but many call them that.
--> This interlock system also ran through the end of the 1976 cars, including all the 1974-76 model year cars.
--> I will need time to review this...have multiple harnesses in inventory and the factory schematic. May take me a couple weeks to respond.
DaveB   1975 Wiring Harness repair - fix or delete seat sensor wiring   Jun 1 2022, 11:57 AM
StarBear   YIKES! :blink:   Jun 1 2022, 02:52 PM
windforfun   Delete the whole harness. Buy a "new" h...   Jun 1 2022, 04:14 PM
DaveB   Delete the whole harness. Buy a "new" ...   Jun 1 2022, 05:29 PM
bbrock   I love being a contrarian :evilgrin: If you have...   Jun 1 2022, 05:05 PM
Superhawk996   Lots of DAPO :stromberg: going on there. As B...   Jun 1 2022, 05:43 PM
Root_Werks   I removed pretty much out of my harness that wasn...   Jun 1 2022, 05:45 PM
john ee quest   I think your PO worked on my 914 cause it looks (t...   Jun 1 2022, 06:03 PM
JeffBowlsby   OP has a 1975 914/4 car. A 914/6 chassis harness ...   Jun 1 2022, 07:23 PM
bbrock   OP has a 1975 914/4 car. A 914/6 chassis harness...   Jun 1 2022, 07:50 PM
mepstein   So many of these cars get parted out. I would look...   Jun 1 2022, 07:41 PM
mepstein   I have a couple used harnesses but I’m not sure ...   Jun 1 2022, 07:56 PM
Luke M   If you have the time redo the harness yourself. I ...   Jun 2 2022, 07:49 AM
peteyd   We have made several /4 chassis harnesses as well....   Jun 2 2022, 09:44 AM
barefoot   Looks like you'd like to understand the harnes...   Jun 2 2022, 10:08 AM
friethmiller   First off, I must say I'm a big fan of Restora...   Jun 2 2022, 10:28 AM
JeffBowlsby   There is no 'early' or 'late' chas...   Jun 2 2022, 11:29 AM
FlacaProductions   RD will sell you the wiring in factory colors/size...   Jun 2 2022, 11:40 AM
914e   RD will sell you the wiring in factory colors/siz...   Jun 2 2022, 06:03 PM
DaveB   I appreciate all the input and suggestions. I d...   Jun 2 2022, 08:25 PM
davep   Does anyone have a 1974 (about March production) c...   Aug 15 2022, 11:03 AM
JeffBowlsby   :wavy: I do. What are the specific differences?   Aug 15 2022, 01:30 PM
davep   Let me start with what goes to pin 31 and pin 85 o...   Aug 19 2022, 09:37 PM
davep   Van B posted this photo which shows that for his c...   Aug 25 2022, 08:45 PM
wonkipop   i'll see if i can get some time over weekend t...   Aug 25 2022, 08:51 PM
ClayPerrine   A word of warning... There is a small black wire ...   Aug 26 2022, 08:10 AM
davep   @JeffBowlsby was there a formal campaign to fix t...   Aug 29 2022, 12:34 PM
JeffBowlsby   was there a formal campaign to fix the interlock s...   Aug 29 2022, 06:00 PM
JeffBowlsby   was there a formal campaign to fix the interlock ...   Aug 29 2022, 06:08 PM
davep   Thanks Jeff. Just had another look at my LE, and n...   Aug 29 2022, 08:07 PM
JeffBowlsby   Dave, that photo above looks odd somehow. A Euro ...   Aug 29 2022, 09:21 PM
davep   Your photo there does not show if there is a spade...   Aug 30 2022, 08:08 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 05:12 PM
