> Ignition Question, My diaphragm was cracked--still not Prego!
Robarabian
post Sep 11 2022, 05:41 PM
914 A Roo
Collective brain trust help needed.
Car is a 1971 1.7. Finished my rebuild, now 1911 CC's. (ECU non adjustable)
Car runs a Pertronix Ignition. Distributor was disassembled, cleaned and re-lubed.
Static timed the car and started it, and ran it for about 18 minutes at 2500-3000 rpm to break in the cam and rings. Did my oil change and then it sat for a few weeks.
Started it to finally set the timing and it started running rough, and I can tell it is on 3 cyl, sometimes 4, and spits, coughs etc. I know it isn't timed right and cant time it until it is on 4 cylinders.
Fuel pressure on an inline gauge is at 30 psi.
Pulled #1 and #2 plugs, they are the right color.
Pulled #3 and #4 and they are wet, and have remnants of being the right color from the cam break in.
Checked all the connections, but don't quite know where to start. The trigger points were clean in the distributor when I disassembled it, and it ran right for cam break in.
Cap, rotor, plugs, wires are all new. MPS holds vacuum.
Thoughts on what I am missing here or where would you start digging first.
I thank you in advance.
Robarabian
post Sep 12 2022, 08:03 PM
914 A Roo
Ok, some progress.
It runs on 4. I brain farted removing the distributor so many times, I switched #3 and #4. I had verified spark first, then looked at the cap and realized the wires were off.
It starts with a turn of the key, cranks a bit slow cause timing is still off but fires easily. Adjusted fuel pressure to 29 psi.
It fires and runs and then dies within a few seconds. If I can get off the key fast enough and work the throttle, it will run and maintain a high rpm, say 2500, but when I release, it will cough and then die. It restarts after resetting the ignition key and giving it a crank.
The cylinder head temp sensor was new from pelican...I verified it is plugged in solid.
Next?
Robarabian   Ignition Question   Sep 11 2022, 05:41 PM
bkrantz   Can you check for spark at #3 and 4?   Sep 11 2022, 08:34 PM
Robarabian   It is on the list for sure. I will disable the fue...   Sep 11 2022, 09:05 PM
JeffBowlsby   All three FI grounds making good contact?   Sep 11 2022, 08:59 PM
Robarabian   YEs, I checked the 3 prong connector and everythin...   Sep 11 2022, 09:04 PM
Robarabian   Ok, some progress. It runs on 4. I brain farted ...   Sep 12 2022, 08:03 PM
emerygt350   I would suspect a lean condition at cold start. I...   Sep 13 2022, 04:50 AM
Robarabian   I have a spare AAR somewhere, I will clean and tes...   Sep 13 2022, 08:23 AM
mgphoto   I have a spare AAR somewhere, I will clean and te...   Sep 13 2022, 09:08 AM
emerygt350   [quote name='Robarabian' post='3029253' date='Sep...   Sep 13 2022, 10:28 AM
Robarabian   I will recheck the injector part numbers, I did re...   Sep 13 2022, 10:44 AM
mgphoto   Your injectors may be to large, you are probably t...   Sep 13 2022, 03:36 PM
Robarabian   Good news. I ordered Tangerine's MPS rebuild k...   Sep 15 2022, 08:05 PM
JeffBowlsby   In your first post you said your “MPS holds vacu...   Sep 15 2022, 08:46 PM
Robarabian   Yeah, I didn't give it long enough when I test...   Sep 15 2022, 09:36 PM
emerygt350   Good find. Make sure you follow Chris's instr...   Sep 16 2022, 04:40 AM
Robarabian   Thank you I intend to. I did order the tool kit as...   Sep 16 2022, 08:10 AM
emerygt350   Thank you I intend to. I did order the tool kit a...   Sep 16 2022, 11:01 AM
- Lo-Fi Version Time is now: 3rd July 2025 - 03:01 AM
