Robarabian |
914 A Roo ![]() ![]() ![]() Group: Members Posts: 695 Joined: 11-February 19 From: Simi Valley, Kalifornia Member No.: 22,865 Region Association: Southern California ![]() ![]() |
Collective brain trust help needed.
Car is a 1971 1.7. Finished my rebuild, now 1911 CC's. (ECU non adjustable) Car runs a Pertronix Ignition. Distributor was disassembled, cleaned and re-lubed. Static timed the car and started it, and ran it for about 18 minutes at 2500-3000 rpm to break in the cam and rings. Did my oil change and then it sat for a few weeks. Started it to finally set the timing and it started running rough, and I can tell it is on 3 cyl, sometimes 4, and spits, coughs etc. I know it isn't timed right and cant time it until it is on 4 cylinders. Fuel pressure on an inline gauge is at 30 psi. Pulled #1 and #2 plugs, they are the right color. Pulled #3 and #4 and they are wet, and have remnants of being the right color from the cam break in. Checked all the connections, but don't quite know where to start. The trigger points were clean in the distributor when I disassembled it, and it ran right for cam break in. Cap, rotor, plugs, wires are all new. MPS holds vacuum. Thoughts on what I am missing here or where would you start digging first. I thank you in advance. |
mgphoto |
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,375 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California ![]() |
Your injectors may be to large, you are probably to rich, even at idle. At this point don’t use a resistor as it just make your setup more rich.
Adjusting the air bypass screw will just make the idle higher. D-Jet is very “touchy” when mixing and matching. Beg borrow or steal an Air Fuel Ratio meter and install the Tangerine kit, a lean air cooled engine will burn up in no time and an overly rich one will wash oil off the cylinder walls and dilute the oil which can damage crank and rod bearings. New motor, just saying. |
Lo-Fi Version | Time is now: 3rd July 2025 - 02:48 AM |
