fixer34 |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,303 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest ![]() ![]() |
I bought the last solid state regulator Mark had hoping to solve my charging issues or at least eliminate it as the problem (can't get more than about 13v while running). I have 3 regulators that have been in the car over the years, but the last/newest one has been there for at least 20 yrs. I don't know if these are bad, good, or somewhere in between and I have no way of testing them. So no idea what they may be worth, if anything. Opinions?
Geezer914 |
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,010 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States ![]() ![]() |
you can adjust these by bending the arm slightly. I have one that puts out 13.8 volts.
lesorubcheek |
Member ![]() ![]() Group: Members Posts: 193 Joined: 21-April 21 From: Florida Member No.: 25,463 Region Association: South East States ![]() |
Here's a kinda neat setup for testing voltage regulators. Need a variable voltage DC supply that can exceed 14V and 12V light for an indicator, or you could substitute with another load meant to handle 12V and use a meter to measure the cutoff voltage.
https://www.thesamba.com/vw/forum/album_pag...?pic_id=1245795 Dan |
fixer34 |
Here's a kinda neat setup for testing voltage regulators. Need a variable voltage DC supply that can exceed 14V and 12V light for an indicator, or you could substitute with another load meant to handle 12V and use a meter to measure the cutoff voltage. https://www.thesamba.com/vw/forum/album_pag...?pic_id=1245795 Dan I'll have to try that on the ones I have. Will see how a 12v test lamp does, some other threads I found say the DF voltage is only 5 to 8/10v |
lesorubcheek |
I'll have to try that on the ones I have. Will see how a 12v test lamp does, some other threads I found say the DF voltage is only 5 to 8/10v It'll be interesting to hear how it works out. I've never dug into understanding charging circuitry beyond diodes in an alternator since that's about all I've ever had to repair. Dan |
Lo-Fi Version | Time is now: 11th July 2025 - 07:27 AM |
