Rear sway bars - Good or Bad ? |
pistonboy |
Sep 20 2022, 08:31 PM
Newbie Group: Members Posts: 38 Joined: 26-October 15 From: California Member No.: 19,305 Region Association: None |
A friend has told me, rear sway bars are suppose to be bad and many people remove them. He says he has heard this from others.
Are rear sway bars good or bad? One of my 914s has the front factory sway bar but no rear sway bar. I have purchased front and rear aftermarket sway bars for one of my vehicles which currently has none, though I have not added them yet. I have also purchased a rear aftermarket sway bar to put on the one that has only the front factory sway bar. Since 914s were designed by Porsche, I find it hard to believe they made a mistake on suspension and handling. These are the things Porsche is famous for. Does anyone have experience with and without rear sway bars and knows. Thank you. |
ClayPerrine |
Sep 21 2022, 07:47 AM
Life's been good to me so far..... Group: Admin Posts: 15,526 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Lots of folks on here say to remove the rear bar. I disagree. With the rear bar, you can run softer springs in the rear and get the same handling as if you put stiffer springs on the rear and removed the bar.
Betty's car was dead neutral and would corner like it was on rails. It had both front and rear bars, and replacement springs on the rear. Clay |
Superhawk996 |
Sep 21 2022, 08:06 AM
914 Guru Group: Members Posts: 5,906 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Lots of folks on here say to remove the rear bar. I disagree. With the rear bar, you can run softer springs in the rear and get the same handling as if you put stiffer springs on the rear and removed the bar. Clay (IMG:style_emoticons/default/agree.gif) - from a engineering design and tuning perspective that is exactly right. Removing the rear bar without doing anything else adds a tendency toward understeer and dulls vehicle turn in. |
Lo-Fi Version | Time is now: 12th June 2024 - 08:20 AM |
