Steering Hub Question, Momo hub - Dino wheel |
MarkV |
May 16 2003, 09:49 PM
Fear the Jack Stands Group: Members Posts: 1,493 Joined: 15-January 03 From: Sunny Tucson, AZ Member No.: 154 Region Association: None |
I have a momo mount & just bout a Dino wheel. The Dino wheel has a slightly larger bolt patern that the Momo hub. Do they still make a Dino hub for a 73 914?
Also looks like the Dino wheel may work better w/ 5mm mach. screws vs. the 4mm the Momo takes. Has anybody re-drilled a Momo hub to fit a Dino wheel? When I mount the hub in the car there is a 1" gap between the Momo hug & the horn mechanism. I assume this gap is for the horn wiper contact. Am I missing a cover or do I have the wrong hub. The hub bolts on w/ no problem. I bouht the hub & wheel from different sellers on e-bay. (IMG:style_emoticons/default/confused24.gif) Attached image(s) |
MarkV |
May 30 2003, 11:09 AM
Read Malmz response above. I think I just bought a paper weight. :finger2:
My car is a 73 and I am almost positive it has the factory column. Early columns are 70-71 only. Andy, do you have a photo of your column minus the wheel? |
Lo-Fi Version | Time is now: 11th June 2024 - 05:35 PM |
