| porschetub |
Sep 27 2022, 03:57 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,209 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Have issue with 2 tach's not working and after testing all connections @ tach and Tach-adapt I'am left with the black/purple wire from the CDI (3 pin) to test.
My later tach (low voltage ) will cause the Tach-adapt LED to come on with the ignition on and the needle bounces when cranking however with engine running ...nothing. My early tach (high voltage) isn't working and this is the one I will convert to Ashlock-tech circuit board replacement but need to know the pulse from CDI is working. TIA,cheers. |
Spoke Most likely the answer is no. Multimeters are good... Sep 27 2022, 04:01 PM
porschetub
Most likely the answer is no. Multimeters are goo... Sep 27 2022, 04:59 PM
Retroracer Agree that a 'scope is best for debug of the C... Sep 27 2022, 07:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 29th November 2026 - 08:31 AM |
