| Stratfink |
Sep 22 2022, 11:03 PM
Member ![]() ![]() Group: Members Posts: 86 Joined: 27-December 21 From: Claremont, CA Member No.: 26,198 Region Association: Southern California
Anyone run these Mobelwagen wheels?
I’m kind of diggin’ the interceptor, but the backspacing on the 15 x 5.5 is 4”. I think they’ll be fine with the 185’s that came with my car but would require some work on the rear fender lips if I ever move to 205’s. They do have the “schnell” for less money and proper backspacing - and kind of look like 4 lug aftermarket Fuchs. They’d go on this car. My 1st 914 that I recently acquired from TDSkip (thanks Tom!). ![]() |
| Montreal914 |
Sep 28 2022, 01:28 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,214 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
Question: How do you balance these wheels? The wheel balancing machines I am familiar with needs a round hole to center the wheel. Do you need some kind of round ring adaptor temporarily mounted to it?
| VaccaRabite |
Sep 28 2022, 07:24 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,929 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
Question: How do you balance these wheels? The wheel balancing machines I am familiar with needs a round hole to center the wheel. Do you need some kind of round ring adaptor temporarily mounted to it? The RoadForce machines that use the hub to mount have a large cone and several adapters so that they can fit almost every wheel. Same could be used here. This is essentially the old aircooled VW T2 wheels done in aluminum instead of steel (and 4 lug, for a beetle instead of a bus). (IMG:http://www.914world.com/bbs2/uploads_offsite/www.jbugs.com-1435-1664371471.1.jpg) Zach |
| type2man |
Sep 28 2022, 10:57 PM
Member ![]() ![]() Group: Members Posts: 355 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
Question: How do you balance these wheels? The wheel balancing machines I am familiar with needs a round hole to center the wheel. Do you need some kind of round ring adaptor temporarily mounted to it? The RoadForce machines that use the hub to mount have a large cone and several adapters so that they can fit almost every wheel. Same could be used here. This is essentially the old aircooled VW T2 wheels done in aluminum instead of steel (and 4 lug, for a beetle instead of a bus). Zach The 4 lug wheels the guy is asking can take a center cone adapter to balance the wheels. The picture you have is a wide 5 wheel and that one needs a center hub adapter.... |
Stratfink Mobelwagen Wheels Sep 22 2022, 11:03 PM
Van B That center would look like crap with the wheel be... Sep 22 2022, 11:06 PM
Craigers17 I kinda like those wheels too. Conversely, if you... Sep 23 2022, 03:24 AM
SirAndy Not hubcentric, no cover for the axle nut and bear... Sep 23 2022, 09:30 AM
jeepguy06 i'm not running those rims but the fuchs look ... Sep 23 2022, 10:23 AM
Literati914 I purchased a set of these while they were offered... Sep 23 2022, 01:10 PM
sixnotfour A Speedster rep. came in with these , decent Whee... Sep 23 2022, 01:28 PM
Bullethead Since they have holes for hubcap clips, has anyone... Sep 23 2022, 02:28 PM
Literati914
A Speedster rep. came in with these , decent Whe... Sep 23 2022, 07:59 PM
Stratfink Thanks for the replies. Helpful and entertainingâ€... Sep 24 2022, 10:02 AM
Craigers17
Oh and the Mobelwagen we... Sep 24 2022, 11:01 AM
jeepguy06 RE: Mobelwagen Wheels Sep 26 2022, 10:15 AM
914rrr
PM sent re: your experience with the 2.0 Fuchs... Jan 6 2024, 02:07 AM
JamesJ Is the fact that they're not hubcentric an iss... Sep 27 2022, 07:30 PM
MM1 According to the link above the Mahle is the light... Sep 28 2022, 11:56 PM
914rrr Does anyone have experience with these Mobelwagen ... Nov 29 2023, 09:00 AM
barefoot I kinda love these at 17"
Nov 30 2023, 06:27 AM
ETMracing
I’m ki... Dec 8 2023, 02:15 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st November 2026 - 07:45 AM |
