| Michael N |
Oct 2 2022, 09:03 PM
Certifiable ![]() ![]() ![]() Group: Members Posts: 1,432 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
I am in the process of changing the standard bulbs in my gauges to LED bulbs. On the 914-6, the far left gauge has the generator bulb that must stay as a filament bulb to keep the charging system working properly. I want to confirm that only the bulb behind the “G”, on the far right of the gauge, is the only bulb that must stay a standard bulb for the charging system to function properly. Can someone confirm for me.
I am also not sure what the indicator light to the left of the “G” indicates. Please chime in if you know. Attached thumbnail(s) |
| worn |
Oct 2 2022, 10:32 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
I am in the process of changing the standard bulbs in my gauges to LED bulbs. On the 914-6, the far left gauge has the generator bulb that must stay as a filament bulb to keep the charging system working properly. I want to confirm that only the bulb behind the “G”, on the far right of the gauge, is the only bulb that must stay a standard bulb for the charging system to function properly. Can someone confirm for me. I am also not sure what the indicator light to the left of the “G” indicates. Please chime in if you know. Oil pressure |
Michael N Need to confirm generator bulb location? Oct 2 2022, 09:03 PM
Dave_Darling The "G" light is the correct one for the... Oct 5 2022, 02:07 AM
rgalla9146
The "G" light is the correct one for th... Oct 5 2022, 06:49 AM
barefoot On my 76 with presumably stock gauge, that white (... Oct 5 2022, 08:00 AM
GregAmy It used to be at http://p914.com/p914_gauges.htm b... Oct 5 2022, 08:26 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 03:38 PM |
