Should I be concerned with this trailing arm? |
peteinjp |
Oct 2 2022, 06:30 AM
Member Group: Members Posts: 201 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
Not running huge tires but 2.7 rs engine and close gears- tires will likely be sticky 205's in the future but on 15x6's with 195's at the moment. Car weight- 970kg (2138lbs.)
Personally it looks a bit questionable but I'm new 914's. Could I use this for a while with plans to upgrade. Should I consider fully reinforcing both arms with this set up? Pete |
peteinjp |
Oct 2 2022, 09:18 PM
Thanks for the responses. It was obviously like this before it was painted and it was aligned etc at Rothsport so I figured they must think is was ok- or didn't notice. I do push the car around a bit in the corners and don't want to worry about this folding in the middle of a drive so I'l replace it.
As long as its being replaced (insert slippery slope here...) I might consider reinforcements. At what point are reinforced arms a good idea. The car may see some autocross but no full on track driving (must have a cage says the rules at my local track- Suzuka.) I do run sticky tires- probably Yokohama A050 or some Avons... But again- limited to 205's. Pete |
ClayPerrine |
Oct 3 2022, 05:56 AM
Life's been good to me so far..... Group: Admin Posts: 15,523 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
As long as its being replaced (insert slippery slope here...) I might consider reinforcements. At what point are reinforced arms a good idea. The car may see some autocross but no full on track driving (must have a cage says the rules at my local track- Suzuka.) I do run sticky tires- probably Yokohama A050 or some Avons... But again- limited to 205's. Pete Pete.. IMHO, I consider trailing arm reinforcements to be a bad idea. Think about your current bent trailing arm. If it were stiffer and couldn't be bent, that would have torn the mounting ear from the chassis. It is much easier to change a trailing arm then to get the mounting ear on the chassis replaced. The trailing arm is like a fuse in an electrical circuit. You want it to fail before the expensive stuff does. Just my $.02. Clay |
Lo-Fi Version | Time is now: 10th June 2024 - 04:39 PM |
