Should I be concerned with this trailing arm? |
peteinjp |
Oct 2 2022, 06:30 AM
Member Group: Members Posts: 201 Joined: 15-July 21 From: Japan Member No.: 25,723 Region Association: None |
Not running huge tires but 2.7 rs engine and close gears- tires will likely be sticky 205's in the future but on 15x6's with 195's at the moment. Car weight- 970kg (2138lbs.)
Personally it looks a bit questionable but I'm new 914's. Could I use this for a while with plans to upgrade. Should I consider fully reinforcing both arms with this set up? Pete |
Retroracer |
Oct 2 2022, 09:33 AM
Senior Member Group: Members Posts: 616 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
Its been compromised. At best its not aligned correctly in the bearing plane, worst case is a failure waiting to happen. These are reasonably easy to find and cheap to replace - find another one?
- Tony |
930cabman |
Oct 3 2022, 10:33 AM
Advanced Member Group: Members Posts: 3,158 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
Its been compromised. At best its not aligned correctly in the bearing plane, worst case is a failure waiting to happen. These are reasonably easy to find and cheap to replace - find another one? - Tony (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) It may never fail, but why take the chance. It is compromised |
Lo-Fi Version | Time is now: 11th June 2024 - 04:08 AM |
