Engine Shroud Refurbishment, There's a hole in my boat |
DennisV |
Oct 1 2022, 07:54 AM
Member Group: Members Posts: 490 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Does anyone have first-hand experience refurbishing their engine shroud that they can share? Best practices? Lessons learned?
I bought the best (err only) original engine shroud that I could find that I think is correct for our engine. Thanks for the guidance on that. It might work as is, but it could sure use some help. Faded. Cracks. Etc. I've done some searching, but the best resources I've found so far are boat repair videos. |
roundtwo |
Oct 3 2022, 12:27 PM
Member Group: Members Posts: 282 Joined: 9-February 20 From: Petaluma, CA Member No.: 23,905 Region Association: Central California |
Great thread as very useful since I’m going through the same resto project.
Recommended paint that’s resistant to oil and gas? I used epoxy to repair a couple of small damaged areas were fasteners had torn out some material. If I had more extensive repairs I think the fiberglass recommendations in this thread were spot on . Primed with 2 k high fill primer to eliminate micro cracks on the surface. Attached thumbnail(s) |
DennisV |
Oct 3 2022, 01:16 PM
Great thread as very useful since I’m going through the same resto project. Recommended paint that’s resistant to oil and gas? I used epoxy to repair a couple of small damaged areas were fasteners had torn out some material. If I had more extensive repairs I think the fiberglass recommendations in this thread were spot on . Primed with 2 k high fill primer to eliminate micro cracks on the surface. Looks like you made some great progress. Did you use a spray can primer like Eastwood offers? What's the best way to remove the rivets without damaging the fiberglass? I guess I could die grind off the top? Maybe this is my justification for getting an oscillating multi-tool? (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 01:58 AM |
