Engine Shroud Refurbishment, There's a hole in my boat |
DennisV |
Oct 1 2022, 07:54 AM
Member Group: Members Posts: 490 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California |
Does anyone have first-hand experience refurbishing their engine shroud that they can share? Best practices? Lessons learned?
I bought the best (err only) original engine shroud that I could find that I think is correct for our engine. Thanks for the guidance on that. It might work as is, but it could sure use some help. Faded. Cracks. Etc. I've done some searching, but the best resources I've found so far are boat repair videos. |
Superhawk996 |
Oct 3 2022, 08:21 PM
914 Guru Group: Members Posts: 5,892 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Check into SprayMax 2k primer and it can also be had as custom color 2k product via a couple paint houses that do business on EBay. I’ve used the one out of Spokane WA with good results for custom color mix.
porschetub |
Oct 3 2022, 09:57 PM
Advanced Member Group: Members Posts: 4,705 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Check into SprayMax 2k primer and it can also be had as custom color 2k product via a couple paint houses that do business on EBay. I’ve used the one out of Spokane WA with good results for custom color mix. End of the day lots of workable options for op,and with the stock air cleaner there isn't much of the shroud to see anyway ,as long it is fitting nicely and sealing on the mounting screws and around the cooler, function is more important in this respect. End result is always worth it,unless you really cock it up (IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/lol-2.gif) . |
Lo-Fi Version | Time is now: 8th June 2024 - 05:56 AM |
