| Michael N |
Oct 2 2022, 09:03 PM
Certifiable ![]() ![]() ![]() Group: Members Posts: 1,432 Joined: 6-June 04 From: San Jose, Ca Member No.: 2,164 Region Association: Northern California |
I am in the process of changing the standard bulbs in my gauges to LED bulbs. On the 914-6, the far left gauge has the generator bulb that must stay as a filament bulb to keep the charging system working properly. I want to confirm that only the bulb behind the āGā, on the far right of the gauge, is the only bulb that must stay a standard bulb for the charging system to function properly. Can someone confirm for me.
I am also not sure what the indicator light to the left of the āGā indicates. Please chime in if you know. Attached thumbnail(s) |
| Dave_Darling |
Oct 5 2022, 02:07 AM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
The "G" light is the correct one for the charging system warning light.
The white circle inboard of that is a blank. In most 914s, it did nothing. In a few (approximately 25) 914-6es, it was a Sportomatic warning light of some kind. Possibly over-temperature? --DD |
Michael N Need to confirm generator bulb location? Oct 2 2022, 09:03 PM
worn
I am in the process of changing the standard bulb... Oct 2 2022, 10:32 PM
rgalla9146
The "G" light is the correct one for th... Oct 5 2022, 06:49 AM
barefoot On my 76 with presumably stock gauge, that white (... Oct 5 2022, 08:00 AM
GregAmy It used to be at http://p914.com/p914_gauges.htm b... Oct 5 2022, 08:26 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:29 PM |
