Axles in our out, I searched but havent found |
nivekdodge |
Oct 12 2022, 03:22 PM
Member Group: Members Posts: 250 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region |
Getting ready to put the motor back in. Axles are out. should i put them in first and work around them or leave them out till motor is in?
Kevin |
914werke |
Oct 12 2022, 07:39 PM
"I got blisters on me fingers" Group: Members Posts: 10,140 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest |
no issue either way unless you are moving the car. If you are you better have at least the stub axels in the wheels or you will destroy your bearings.
rgalla9146 |
Oct 13 2022, 06:17 AM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
no issue either way unless you are moving the car. If you are you better have at least the stub axels in the wheels or you will destroy your bearings. (IMG:style_emoticons/default/agree.gif) Stub axles out ? Have to move the car ? Easy. See pic. Use this or your version of it to tighten the bearing races to each other to prevent damage. PS, those big fat washers can be found a older Porsche repair shops. They were used to raise bumper height on '70s 911s Attached thumbnail(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 02:31 PM |
