| 914_7T3 |
Dec 24 2018, 03:10 PM
Please forgive me, I'm new to all of this! ![]() ![]() ![]() Group: Members Posts: 1,894 Joined: 3-April 17 From: Los Angeles, CA Member No.: 20,991 Region Association: Southern California
Used the clips that come with The Genuine Porsche OEM trim kit From Sierra Madre and important to note that they do not break as easily as the aftermarket ones. Drawback is that they were one clip short in the package. Luckily our 914World Designated Windshield Installer had a spare.
![]() Once clips were in, a Butyl Primer was used as recommended in the below thread. http://914world.com/bbs2/index.php?showtopic=312146 ![]() Windshield was warmed up in the sun prior to install. ![]() 5/16 Butyl Primer is used and the glass positioned and seated. ![]() ![]() Snap in the trim clips and you're good to go. ![]() The windshield I am using is a Sekurit from Finland and it seems to not sit 100% flush in some areas. As a result, it takes some finessing to make sure there is enough clearance for the trim to notch comfortably into the clips. The takeaway here is to use a professional installer if you do not have the suction tool or have not done a windshield install before! |
| nivekdodge |
Oct 28 2022, 07:38 AM
Member ![]() ![]() Group: Members Posts: 331 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region
I’ve been been reading a lot of these glass install posts. Non of them give a reason for using butyl other than “that’s the way we’ve always done it”. Does anyone have a concrete reason why you would use 50 year old tech?
| bbrock |
Oct 28 2022, 07:48 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
I’ve been been reading a lot of these glass install posts. Non of them give a reason for using butyl other than “that’s the way we’ve always done it”. Does anyone have a concrete reason why you would use 50 year old tech? Surprised you didn't come across this in other threads as it comes up quite a bit, but the reason is because our cars flex and urethane doesn't. Quite a few reports of people having their windshields crack after installing with urethane. |
914_7T3 Windshield Installation: Dec 24 2018, 03:10 PM
914Sixer Don't see bottom windshield spacer ? Dec 24 2018, 03:20 PM
914_7T3
There... Dec 24 2018, 03:22 PM
cuddy_k Nice write up...and glad the glass is in! Dec 24 2018, 05:14 PM
HansJan Installing the windshield is a lot easier then it ... Dec 24 2018, 09:19 PM
buck toenges Can you add the chrome trim pieces on later or doe... Dec 24 2018, 10:46 PM
HansJan
Can you add the chrome trim pieces on later or do... Dec 24 2018, 11:21 PM
Tdskip Thanks for the write up and discussion, very helpf... Dec 24 2018, 11:38 PM
Larmo63 I assume you used Ruffino to install your windshie... Dec 25 2018, 11:56 AM
914_7T3
I assume you used Ruffino to install your windshi... Dec 26 2018, 08:08 PM
IronHillRestorations A couple body & glass guys I know recommended ... Dec 25 2018, 01:47 PM
cuddy_k I removed and replaced the windshield on my '7... Dec 25 2018, 03:09 PM
Tdskip Anyone have a close up picture of how the clip and... Dec 26 2018, 08:05 AM
mepstein Primer is just used to help the butyl tape stick b... Dec 26 2018, 08:18 AM
Tdskip
Primer is just used to help the butyl tape stick ... Dec 26 2018, 09:42 AM
Costa05 Great advise on this thread. Thx. I am planning to... Dec 26 2018, 10:02 AM
Mikey914
Great advise on this thread. Thx. I am planning t... Jan 6 2019, 12:17 PM
buck toenges 914 rubber includes instructions on their butyl ta... Jan 2 2019, 07:48 PM
cuddy_k On the CRL primer, the dabber is integrated into t... Jan 2 2019, 09:15 PM
Robarabian It flexes. The urethane of today's cars is ver... Oct 28 2022, 07:21 PM
bkrantz
I’ve been been reading a lot of these glass ins... Oct 28 2022, 08:04 PM
930cabman
I’ve been been reading a lot of these glass in... Nov 2 2022, 05:07 AM
914werke :agree: These cars were flexi-flyers when new (esp... Oct 28 2022, 10:32 AM
mepstein Yea. People want to modernize the install and the ... Oct 28 2022, 02:22 PM
nivekdodge Thanks guys
Kevin Oct 28 2022, 02:51 PM
VaccaRabite I've had my windshield glued in with urethane ... Nov 2 2022, 06:00 AM
930cabman
I've had my windshield glued in with urethane... Nov 2 2022, 06:25 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:41 PM |
