> Windshield Installation:, Things to Note
914_7T3
post Dec 24 2018, 03:10 PM
Used the clips that come with The Genuine Porsche OEM trim kit From Sierra Madre and important to note that they do not break as easily as the aftermarket ones. Drawback is that they were one clip short in the package. Luckily our 914World Designated Windshield Installer had a spare.
Once clips were in, a Butyl Primer was used as recommended in the below thread.
http://914world.com/bbs2/index.php?showtopic=312146
Windshield was warmed up in the sun prior to install.
5/16 Butyl Primer is used and the glass positioned and seated.
Snap in the trim clips and you're good to go.
The windshield I am using is a Sekurit from Finland and it seems to not sit 100% flush in some areas. As a result, it takes some finessing to make sure there is enough clearance for the trim to notch comfortably into the clips.
The takeaway here is to use a professional installer if you do not have the suction tool or have not done a windshield install before!
nivekdodge
post Oct 28 2022, 07:38 AM
I’ve been been reading a lot of these glass install posts. Non of them give a reason for using butyl other than “that’s the way we’ve always done it”. Does anyone have a concrete reason why you would use 50 year old tech?
bkrantz
post Oct 28 2022, 08:04 PM
QUOTE(nivekdodge @ Oct 28 2022, 07:38 AM) *
The common explanation is that butyl tape provides a bit more give, so as the windshield frame flexes, the glass is less likely to crack.
930cabman
post Nov 2 2022, 05:07 AM
QUOTE(bkrantz @ Oct 28 2022, 08:04 PM) *
exactly, something like cement mortar vs lime mortar in masonry construction. The more "flexible" lime mortar wins out everytime in historic buildings.
Rigid is not always a good thing
914_7T3   Windshield Installation:   Dec 24 2018, 03:10 PM
914Sixer   Don't see bottom windshield spacer ?   Dec 24 2018, 03:20 PM
914_7T3   Don't see bottom windshield spacer ? There...   Dec 24 2018, 03:22 PM
cuddy_k   Nice write up...and glad the glass is in!   Dec 24 2018, 05:14 PM
HansJan   Installing the windshield is a lot easier then it ...   Dec 24 2018, 09:19 PM
buck toenges   Can you add the chrome trim pieces on later or doe...   Dec 24 2018, 10:46 PM
HansJan   Can you add the chrome trim pieces on later or do...   Dec 24 2018, 11:21 PM
Tdskip   Thanks for the write up and discussion, very helpf...   Dec 24 2018, 11:38 PM
Larmo63   I assume you used Ruffino to install your windshie...   Dec 25 2018, 11:56 AM
914_7T3   I assume you used Ruffino to install your windshi...   Dec 26 2018, 08:08 PM
IronHillRestorations   A couple body & glass guys I know recommended ...   Dec 25 2018, 01:47 PM
cuddy_k   I removed and replaced the windshield on my '7...   Dec 25 2018, 03:09 PM
Tdskip   Anyone have a close up picture of how the clip and...   Dec 26 2018, 08:05 AM
mepstein   Primer is just used to help the butyl tape stick b...   Dec 26 2018, 08:18 AM
Tdskip   Primer is just used to help the butyl tape stick ...   Dec 26 2018, 09:42 AM
Costa05   Great advise on this thread. Thx. I am planning to...   Dec 26 2018, 10:02 AM
Mikey914   Great advise on this thread. Thx. I am planning t...   Jan 6 2019, 12:17 PM
buck toenges   914 rubber includes instructions on their butyl ta...   Jan 2 2019, 07:48 PM
cuddy_k   On the CRL primer, the dabber is integrated into t...   Jan 2 2019, 09:15 PM
nivekdodge   I’ve been been reading a lot of these glass inst...   Oct 28 2022, 07:38 AM
bbrock   I’ve been been reading a lot of these glass ins...   Oct 28 2022, 07:48 AM
Robarabian   It flexes. The urethane of today's cars is ver...   Oct 28 2022, 07:21 PM
bkrantz   I’ve been been reading a lot of these glass ins...   Oct 28 2022, 08:04 PM
930cabman   I’ve been been reading a lot of these glass in...   Nov 2 2022, 05:07 AM
914werke   :agree: These cars were flexi-flyers when new (esp...   Oct 28 2022, 10:32 AM
mepstein   Yea. People want to modernize the install and the ...   Oct 28 2022, 02:22 PM
nivekdodge   Thanks guys Kevin   Oct 28 2022, 02:51 PM
VaccaRabite   I've had my windshield glued in with urethane ...   Nov 2 2022, 06:00 AM
930cabman   I've had my windshield glued in with urethane...   Nov 2 2022, 06:25 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 06:40 PM
