> CV joints and transmission question
narino
post Jun 29 2022, 06:59 PM
Hi all,
I'm back to working on the forever project. I started looking over old items a nightmare mechanic did several years ago. I wanted to get your thoughts on a few items before I get in too deep.
Previous mechanic changed my CV joints. Didn't think to ever check them after the that. I took a look a few days ago and noticed the joints seem to be throwing a lot of grease. Boots looked OK though. After wiping some grease off the joint it looks like I might be missing the paper gasket. From watching Ian Karr's video on CV joints it looks like the paper gasket is thick and flush to the outside. Thoughts? See image below for reference.
Also, the CV bolt clamp plates seem to be missing. I'm sure the schnorr washer is missing as well.
Transmission - I'm still having issues with 3rd and 5th. I read you can carefully use a scissor jack between the back of the transmission (muffler off) and the body to push the tranny/engine assembly forward. I took a look and couldn't find a safe place to place the jack against the body without possibly bending something. The only thing there seems to be the edge of the heat shielding for the muffler. Has anyone done this that could offer direction? See second image below.
Because I don't trust anything this mechanic did back in the day, I'm posting the 3rd image to see if this is normal. The bottom of the transmission by the bellhousing has a small window that looks open. Is this correct, or is it supposed to be closed/gasketed?
Lastly, does anyone have a body shop in the Los Angeles area that knows 914s that they could recommend? Or can I buy some time from a local knowledgeable teener to take a look at her for me? I need help assessing the dreaded rust issue..
Thanks all!
914Sixer
post Nov 28 2022, 07:01 AM
I use anti seize on stub axles.
narino   CV joints and transmission question   Jun 29 2022, 06:59 PM
914werke   CV gaskets - YES Plates & schoore washers - YE...   Jun 29 2022, 07:10 PM
narino   Thank you for the reply Rich. I'll tear thes...   Jun 29 2022, 09:03 PM
narino   Got the passenger side CV joint off. Surprisingly ...   Jul 2 2022, 03:38 PM
914e   Got the passenger side CV joint off. Surprisingly...   Jul 3 2022, 11:21 AM
narino   Thank you 914e! I'll order new bolts.   Jul 3 2022, 11:26 AM
narino   Crap. So one CV had hex bit bolts. So i STUPIDLY a...   Jul 4 2022, 05:02 PM
914e   Crap. So one CV had hex bit bolts. So i STUPIDLY ...   Jul 4 2022, 05:40 PM
narino   @914e finger tight CV bolts is a scary thought. G...   Jul 4 2022, 10:31 PM
mgphoto   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jul 5 2022, 12:00 AM
Dave_Darling   There are a number of people who feel that the CV ...   Jul 5 2022, 03:18 AM
narino   I got the axles off! 1/2" breaker bar wi...   Jul 8 2022, 04:29 PM
914werke   HERE :wavebye:   Jul 8 2022, 05:23 PM
narino   Hi @914werke The washer I'm looking for sit...   Jul 8 2022, 05:29 PM
914werke   The concave washer?   Jul 8 2022, 05:30 PM
narino   The concave washer? Yep, i need 4. Only one CV ...   Jul 8 2022, 06:02 PM
narino   With stub axles out, do I need to protect the whee...   Jul 8 2022, 10:25 PM
mgphoto   With stub axles out, do I need to protect the whe...   Jul 8 2022, 11:55 PM
narino   Clean with dry rags, maybe some brake cleaner, do...   Jul 9 2022, 09:35 PM
narino   After another long pause due to life/work, I'm...   Nov 28 2022, 01:43 AM
bdstone914   After another long pause due to life/work, I...   Aug 27 2024, 12:04 AM
914Sixer   I use anti seize on stub axles.   Nov 28 2022, 07:01 AM
narino   Necro-reviving my own topic. Went to rebuild the ...   Aug 24 2024, 02:39 PM
narino   Monday morning bump.   Aug 26 2024, 11:59 AM
Chi-town   Side with no stamping goes to the shaft Thinner ed...   Aug 26 2024, 09:28 PM
narino   @Chi-town - Thank you, Dylan! [b]@[url=htt...   Aug 27 2024, 09:14 AM
- Lo-Fi Version Time is now: 30th April 2026 - 09:14 AM
