| rosenfe |
Aug 23 2020, 03:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 565 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
I plant to clean top,not sand. Any recommendations for spray paint choice in black
| IronHillRestorations |
Aug 23 2020, 06:55 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,922 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
Clean it with a strong mix of soap and water a couple times, maybe even add a little TSP in it if you've got it.
Then I'd go over it with solvent cleaner like PreSol, Klix88, or Acme Solvent cleaner. Use two rags, one with the solvent and the other to wipe off. Change rags as they get dirty and don't stop cleaning until you wipe and your wipe off rag is clean. This doesn't mean you still won't have trouble with oil spotting, because you may. 45+ year old fiberglass roofs have be coated with Armorall, wax, shoe polish, silicone, and a host of other treatments that can impregnate the fiberglass. Your best pre-paint action is to clean, clean, and clean more. In a perfect world, you'd use an catalyzed, flattened (to the right level of low sheen), automotive finish type paint, but that's not always practical. I've got a car in my shop right now that needs the roof painted, and we're going to try a single stage rattle can epoxy VHT Epoxy All Weather Satin Black VHT Satin Black Epoxy I've been using it on suspension components and engine tins, and I like the finish and how it goes on. Time will only tell how durable it really is. Anything in a rattle can probably won't be as good as "real" auto paint, but ease of use is a plus. I get it from my local NAPA store. Online retailers may have it, but some really over charge for it |
| StarBear |
Dec 3 2022, 09:36 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,241 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
Clean it with a strong mix of soap and water a couple times, maybe even add a little TSP in it if you've got it. Then I'd go over it with solvent cleaner like PreSol, Klix88, or Acme Solvent cleaner. Use two rags, one with the solvent and the other to wipe off. Change rags as they get dirty and don't stop cleaning until you wipe and your wipe off rag is clean. This doesn't mean you still won't have trouble with oil spotting, because you may. 45+ year old fiberglass roofs have be coated with Armorall, wax, shoe polish, silicone, and a host of other treatments that can impregnate the fiberglass. Your best pre-paint action is to clean, clean, and clean more. In a perfect world, you'd use an catalyzed, flattened (to the right level of low sheen), automotive finish type paint, but that's not always practical. I've got a car in my shop right now that needs the roof painted, and we're going to try a single stage rattle can epoxy VHT Epoxy All Weather Satin Black VHT Satin Black Epoxy I've been using it on suspension components and engine tins, and I like the finish and how it goes on. Time will only tell how durable it really is. Anything in a rattle can probably won't be as good as "real" auto paint, but ease of use is a plus. I get it from my local NAPA store. Online retailers may have it, but some really over charge for it @IronHillRestorations Thinking of my winter projects and painting my targa top - searched and found your suggestion. Mine is original, texture is fine but bunches of various spots over the years. Was wondering - your suggestion is lots of soap and water: dishsoap? something milder? stronger? Also, a thread on Pelican suggests using alcohol. Your thoughts? Like many others, the top has many years of treatment, black shoe polish, and lately small dots of black Sharpie, so probably lots of hidden pockets of gunk in the texture valleys. Finally, I use Wurth Satin Black for trim - OK for the top, or do the SEM Trim Satin? Thanks! |
rosenfe Paint for black targa top Aug 23 2020, 03:14 PM
Tdskip Super helpful post as usual, thanks @IronHillRest... Aug 23 2020, 08:48 PM
Tonyooc I sprayed mine with a product called Raptor. You ... Aug 23 2020, 08:59 PM
Montreal914 :popcorn: Aug 23 2020, 09:55 PM
PCH After cleaning, sprayed mine with a rattle can. Us... Aug 23 2020, 11:34 PM
Lucky9146 Had great results with SEM Trim Black. Cleaned to... Aug 24 2020, 12:01 AM
Had great results with SEM Trim Black. Cleaned t... Aug 24 2020, 03:49 PM
Nojoah
Had great results with SEM Trim Black. Cleaned t... Aug 24 2020, 05:46 PM
930cabman If I recall correctly BBrock did his a year or so ... Dec 3 2022, 10:59 AM
nivekdodge Sem 39144 is the same trim black in qt liquid form... Dec 3 2022, 11:26 PM
IronHillRestorations @StarBear I suggest a stronger detergent than di... Dec 4 2022, 07:20 AM
StarBear
[b]@[url=http://www.914world.com/bbs2/index.php?s... Dec 4 2022, 08:58 AM
[b]@[url=http://www.914world.com/bbs2/index.php?... Dec 5 2022, 07:19 AM
mlindner I need to paint mine also, but I need to get back ... Dec 5 2022, 08:00 AM
dr914@autoatlanta.com if the top has been sanded smooth, you will have t... Dec 5 2022, 09:03 AM
Root_Werks The top that came with my 914 was so bad, it was t... Dec 5 2022, 10:18 AM
windforfun
I plant to clean top,not sand. Any recommendatio... Dec 5 2022, 07:47 PM
StarBear Refresh done!
Followed suggestions posted her... Dec 12 2022, 01:15 PM
76-914 Looks great! I have that on my "to do... Dec 12 2022, 02:38 PM
StarBear
Looks great! I have that on my "to do... Dec 12 2022, 04:15 PM
76-914
Looks great! I have that on my "to do... Dec 12 2022, 05:24 PM
eric9144 looks great!! :beer2: Dec 12 2022, 05:07 PM
roundtwo All great info plus…
If needing retexture, sugg... Dec 12 2022, 05:49 PM
StarBear No trouble keeping a wet edge with the SEM spray. ... Dec 12 2022, 05:54 PM
IronHillRestorations Nice work!! It looks great! Dec 13 2022, 06:40 AM
Literati914
After cleaning, sprayed mine with a rattle can. [... Dec 13 2022, 09:51 AM
StarBear
After cleaning, sprayed mine with a rattle can. ... Dec 13 2022, 10:06 AM![]() ![]() |
Lo-Fi Version | Time is now: 15th March 2026 - 11:04 PM |
