| doobie123 |
Nov 28 2022, 12:51 PM
Member ![]() ![]() Group: Members Posts: 86 Joined: 8-July 22 From: tucson Member No.: 26,683 Region Association: Southwest Region |
hi, working on a 1975 914 1,8 5spd.
so; i'm replacing the rear cover for the transmission. its the cover that the speedo drive is located in. i have it on but, i can't seem to get it to go on all the way. it is setting about 1/8" from seating all thew. i don't want to tighten the nuts until i can find out if this is normal or is there something i've missed or have out of alingment. any suggestions would be great! thanks. ive enclosed a pic |
| rbzymek |
Dec 2 2022, 08:41 PM
Member ![]() ![]() Group: Members Posts: 201 Joined: 5-April 19 From: Northville, MI Member No.: 23,013 Region Association: Upper MidWest
The reverse gear set (the loose bits) has a spacer at the bottom that has a moon shape cut that allows it to fully seat. If it is not properly on place it will not allow the gear set to fully seat. Pop the cover and remove the reverse bits to make sure it is seated correctly. The spacer is about as thick as the gap you are experiencing.
| doobie123 |
Dec 3 2022, 09:53 AM
The reverse gear set (the loose bits) has a spacer at the bottom that has a moon shape cut that allows it to fully seat. If it is not properly on place it will not allow the gear set to fully seat. Pop the cover and remove the reverse bits to make sure it is seated correctly. The spacer is about as thick as the gap you are experiencing. /Users/ginger/Desktop/IMG-2679.jpg ok i have the drive on and that must be the issue. i have the spacer with the "moon" cut in place and the spacer and bearing races on the reverse shaft but in spite of my bag and tag process, these wound up on the bench. can anyone I.D. them? |
| doobie123 |
Dec 3 2022, 01:28 PM
The reverse gear set (the loose bits) has a spacer at the bottom that has a moon shape cut that allows it to fully seat. If it is not properly on place it will not allow the gear set to fully seat. Pop the cover and remove the reverse bits to make sure it is seated correctly. The spacer is about as thick as the gap you are experiencing. /Users/ginger/Desktop/IMG-2679.jpg ok i have the drive on and that must be the issue. i have the spacer with the "moon" cut in place and the spacer and bearing races on the reverse shaft but in spite of my bag and tag process, these wound up on the bench. can anyone I.D. them? ok so i attached a pic of the position of the cut spacer. i also attached a pic of the inside of the cover and the trans gears. in the center of the cover there looks to be a bushing. the speedo gear coming out of the trans appears to be hitting that bush. on the old cover, that piece has worn away and i can not see what was there. it looks like, if that bushing was gone, it would work. can i remove that and not use it? it must be there for a reason. the numbers on the old and replacement case are the same. any help would be great! thanks |
| doobie123 |
Dec 3 2022, 01:29 PM
The reverse gear set (the loose bits) has a spacer at the bottom that has a moon shape cut that allows it to fully seat. If it is not properly on place it will not allow the gear set to fully seat. Pop the cover and remove the reverse bits to make sure it is seated correctly. The spacer is about as thick as the gap you are experiencing. /Users/ginger/Desktop/IMG-2679.jpg ok i have the drive on and that must be the issue. i have the spacer with the "moon" cut in place and the spacer and bearing races on the reverse shaft but in spite of my bag and tag process, these wound up on the bench. can anyone I.D. them? ok so i attached a pic of the position of the cut spacer. i also attached a pic of the inside of the cover and the trans gears. in the center of the cover there looks to be a bushing. the speedo gear coming out of the trans appears to be hitting that bush. on the old cover, that piece has worn away and i can not see what was there. it looks like, if that bushing was gone, it would work. can i remove that and not use it? it must be there for a reason. the numbers on the old and replacement case are the same. any help would be great! thanks forgot to add this one |
doobie123 trans cover Nov 28 2022, 12:51 PM
mepstein Nope. It has to completely close the gap. There... Nov 28 2022, 12:57 PM
doobie123
Nope. It has to completely close the gap. There... Dec 2 2022, 11:37 AM
porschetub
Nope. It has to completely close the gap. There... Dec 2 2022, 08:06 PM
r_towle I might suggest a dry fit with no gasket.
It shoul... Dec 4 2022, 05:22 AM
doobie123 thanks for all the comments so far.
here is what ... Dec 5 2022, 09:49 AM
ejm Looks like the bushing from the old cover is stuck... Dec 5 2022, 12:06 PM
mb911 The RTV pictured is frowned upon. The gasket helps... Dec 5 2022, 12:43 PM
Dave_Darling The pinion depth is set by the gaskets between the... Dec 6 2022, 04:20 AM
brant was the old cover with the hole in it... caused b... Dec 6 2022, 10:54 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 08:46 PM |
