| The Double S |
Dec 4 2022, 02:45 PM
Member ![]() ![]() Group: Members Posts: 93 Joined: 8-October 19 From: Upland, CA Member No.: 23,545 Region Association: Southern California |
For folks that have a Boxster S 6speed transaxle and are using 911 Carrera GKN/Loebro axles (Porsche PT# 91133202415 / GKN PT# 300 758) :
1. What spacers are you using in your 914 for fitment? 2. Where did you source them? Thanks in advance! |
| tygaboy |
Dec 4 2022, 06:20 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,830 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
@The Double S - That's the same set up I'm running in my LS car. You need:
- 1/2" spacers between the trans output shafts and the inner CVs along with appropriately longer bolts. Make your own spacer or contact Renegade Hybrids - they supplied mine. - At the hub end, you'll need a special spacer from Patrick Motorsports, available here: https://patrickmotorsports.com/collections/...914331aspextpms |
| The Double S |
Dec 4 2022, 07:22 PM
@The Double S - That's the same set up I'm running in my LS car. You need: - 1/2" spacers between the trans output shafts and the inner CVs along with appropriately longer bolts. Make your own spacer or contact Renegade Hybrids - they supplied mine. - At the hub end, you'll need a special spacer from Patrick Motorsports, available here: https://patrickmotorsports.com/collections/...914331aspextpms Hey Chris! Actually we talked about this a little while back when I was receiving mismatched axles with the same part numbers. When I reached out to Renegade they seemed like they didn't know what I was talking about when I described it to them but I will give it another shot and call them tomorrow. Unfortunately I don't have the tooling to make them myself. Think there might be another vendor to supply the 1/2" spacers in the case Renegade can't? |
The Double S Boxster S Transaxle & 911 Carrera Axles: What spacers are needed? Dec 4 2022, 02:45 PM
Cairo94507 What is that 6-speed going behind? What are you u... Dec 4 2022, 03:45 PM
The Double S LS1 and the stock Boxster S shifter Dec 4 2022, 04:40 PM
Cairo94507 Very nice. :beer2: Dec 4 2022, 05:34 PM
@[url=http://www.914world.com/bbs2/index.php?show... Dec 8 2022, 05:05 PM
mb911
[quote name='tygaboy' post='3043060' date='Dec 4 ... Dec 8 2022, 05:29 PM
[quote name='tygaboy' post='3043060' date='Dec 4... Dec 8 2022, 05:37 PM
mb911
[quote name='mb911' post='3043995' date='Dec 8 20... Dec 9 2022, 12:43 PM
tygaboy I got the spacers from Renegade as a part from the... Dec 4 2022, 07:49 PM
The Double S No dice. Renegade is telling me that they don... Dec 5 2022, 01:15 PM
tygaboy I just did a quick search for "911 CV spacer... Dec 5 2022, 02:19 PM
ClayPerrine If you have 911 hubs, 911 water cooled axles bolt ... Dec 7 2022, 06:50 AM
The Double S
If you have 911 hubs, 911 water cooled axles bolt... Dec 7 2022, 01:21 PM
ClayPerrine
[quote name='ClayPerrine' post='3043606' date='De... Dec 8 2022, 03:52 PM
The Double S Thanks. I feel like we may be talking about separa... Dec 8 2022, 04:35 PM
ClayPerrine
Thanks. I feel like we may be talking about separ... Dec 9 2022, 06:35 AM
BIGKAT_83 For the 5mm spacer (washer) you need for the hub t... Dec 8 2022, 05:43 PM
mepstein For the 5mm spacer (washer) you need for the hub t... Dec 8 2022, 06:42 PM
The Double S @BIGKAT_83 Thank you for chiming in. I was about ... Dec 9 2022, 12:29 AM
The Double S Thanks Clay. I understand now and I didn't kno... Dec 9 2022, 12:53 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th June 2026 - 06:08 PM |
