> trans cover, is it on yet?
doobie123
post Nov 28 2022, 12:51 PM
hi, working on a 1975 914 1,8 5spd.
so; i'm replacing the rear cover for the transmission. its the cover that the speedo drive is located in.
i have it on but, i can't seem to get it to go on all the way. it is setting about 1/8" from seating all thew. i don't want to tighten the nuts until i can find out if this is normal or is there something i've missed or have out of alingment.
any suggestions would be great!
thanks. ive enclosed a pic
doobie123
post Dec 5 2022, 09:49 AM
thanks for all the comments so far.
here is what i've found.
after pulling the speedo drive i have the same problem. so i took a bore scope and had a look and i've attached a pic. the rod coming out of the trans that has the speedo gear on it, is hitting the case. i think the old case had the same problem and thats why it wore a hole in the case. so my questions are, is there a different case? or can i change the rod to a smaller one? is it possible to cut the rod or remove some material from the case? is there something else going on with the trans?
thanksAttached Image Attached Image Attached Image
- Lo-Fi Version Time is now: 7th December 2025 - 08:46 PM
