| NARP74 |
Dec 5 2022, 02:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,448 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
The car I bought this summer came with a Rennshift in it with a Tangerine Racing precision shift adjuster installed. I know people don't like them, but it was in already. So I was going through some adjustments with that and found I had a clutch problem caused by a pedal board adjustment. That led me to a clutch cable issue in the back. Got that all sorted and that is where the chasing my tail started.
I cannot tell if my current shift problems are clutch or shifter adjustment issues. I have not found any definitive clutch adjustment specs, seems like you do it by feel and pedal travel. And I try to go to the shifter adjustments and it feels like clutch issues. Back and forth Need help isolating the two and and getting things worked out. Where to start? I am only one set of hands and eyes and that makes things a little harder too. Suggestions appreciated. |
| rjames |
Dec 5 2022, 03:04 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,461 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
Yeah, the Rennshift and Tangerine adjuster are horrible. You should remove them and just send them to me for disposal. I'll happily pay shipping. (IMG:style_emoticons/default/happy11.gif)
Seriously though, I've only read fantastic things about both products. There's probably a specific adjustment for the Rennshit, so I'll let others comment on that, but here are the 2 reference points for adjusting the clutch and stock shifter that should also mostly apply to your setup. Clutch Adjustment Instructions Shifter Adjustment Instructions |
NARP74 Clutch v Shift Linkage Dec 5 2022, 02:48 PM
NARP74
Yeah, the Rennshift and Tangerine adjuster are ho... Dec 5 2022, 03:41 PM
brant I vaguely recall the haynes manual having clutch a... Dec 5 2022, 03:09 PM
NARP74
I vaguely recall the haynes manual having clutch ... Dec 5 2022, 03:42 PM
914Toy I had a shift link adjust problem after installing... Dec 5 2022, 04:06 PM
NARP74
I had a shift link adjust problem after installin... Dec 5 2022, 04:19 PM
NARP74 The problem with the threads mentioned is that the... Dec 5 2022, 05:04 PM
Dave_Darling Clutch free play is measured with the clutch pedal... Dec 6 2022, 04:16 AM
ChrisFoley Did you get copies of the instructions for those u... Dec 6 2022, 06:24 AM
NARP74
Did you get copies of the instructions for those ... Dec 6 2022, 11:10 AM
ChrisFoley If you don't have a friend to help, can you se... Dec 6 2022, 06:29 AM
JWest Not sure where "don't like them" com... Dec 6 2022, 10:08 AM
NARP74
Not sure where "don't like them" co... Dec 6 2022, 11:13 AM![]() ![]() |
Lo-Fi Version | Time is now: 24th June 2026 - 10:03 PM |
