> Parts for 2056, Where to source parts
sjhenry1075
post Dec 8 2022, 09:22 AM
Hey everyone,
I'm in the process of sourcing parts for my 2056 build. I was able to find 2.0 heads that will be rebuilt by a local machine shop, and I found a set of very nice 40 IDF Weber carbs. I'll also be using my 1.7 case.
My question is this: for the engine internals, where can I find these parts? I did see on the Fat Rimco website that they sell a short block kit for $2650 that includes the following:
FAT Camshaft FC 442 Camshaft / FC 440 If Smog
71mm Type 4 Crankshaft
2.0 Connecting Rods - Rebuilt
96mm Forged Pistons & Cylinders - Keith Black
WEB Lifters
Front Oil Seal
Rear Main Seal
Gasket Set - German
Engine Hardware Kit - Nuts & Bolts
Main Bearings - Silverline
Rod Bearings - Mahle
HD Double Thrust Cam Bearings (2 Sets of STD)
What does everyone think about the price? I know some would not refer Fat Rimco for an engine build, but they will just supply the parts, not doing the actual build.
Thoughts?
JamesJ
post Dec 9 2022, 12:17 PM
Not to pull away from OP's question, but it is related. I just had a 2056 "professionally" built with a Raby 9590 cam and am running 8.8:1 compression with stock L-jet. The car ran like a champ for 300 miles, then the engine locked up. When I remove the engine, I am considering lowering the compression. Is that a good idea?
post Dec 9 2022, 12:53 PM
914-6 GT in waiting
QUOTE(JamesJ @ Dec 9 2022, 01:17 PM) *
You really have to figure out what made the engine lock up. It wasn’t the 8.8 compression ratio - at least not independent of other issues.
JamesJ
post Dec 9 2022, 06:46 PM
[/quote]
[/quote]
Yes, thank you. I know they are unrelated. My ? was should I lower the compression ratio while I have the engine apart.
If my comments help the OP, then great. Otherwise, feel free to PM me with comments.
TIA
sjhenry1075
post Dec 9 2022, 08:54 PM
[quote name='JamesJ' date='Dec 9 2022, 07:46 PM' post='3044278']
[/quote]
[/quote]
TIA
[/quote]
Doesn’t bother me at all, post away
sjhenry1075   Parts for 2056   Dec 8 2022, 09:22 AM
Montreal914   Parts and machining: European Motorworks in Hawtho...   Dec 8 2022, 10:05 AM
930cabman   All good suggestions, may I add: D Elgin camshaft...   Dec 8 2022, 10:22 AM
914werke   If you local machine shop has the ability to do th...   Dec 8 2022, 11:16 AM
sjhenry1075   If you local machine shop has the ability to do t...   Dec 8 2022, 11:21 AM
sportlicherFahrer   I picked up a nice set of pistons and cylinders an...   Dec 8 2022, 11:28 AM
barefoot   You didn't mention any work needed on the case...   Dec 8 2022, 03:59 PM
mepstein   Billy Ring Performance auto works Kerneysville WV ...   Dec 8 2022, 04:56 PM
BeatNavy   Billy Ring Performance auto works Kerneysville WV...   Dec 8 2022, 07:25 PM
sjhenry1075   Billy Ring Performance auto works Kerneysville W...   Dec 9 2022, 05:57 AM
BeatNavy   There's a ton of people here who can wax more ...   Dec 9 2022, 06:34 AM
sjhenry1075   There's a ton of people here who can wax more...   Dec 9 2022, 08:48 AM
VaccaRabite   Don't you have a 2056? What cam did you use?...   Dec 9 2022, 10:00 AM
sjhenry1075   Don't you have a 2056? What cam did you use...   Dec 9 2022, 10:08 AM
930cabman   I am no professional engine builder, but have buil...   Dec 9 2022, 08:48 AM
barringtonpro   I am no professional engine builder, but have bui...   Feb 6 2023, 06:59 AM
VaccaRabite   I am no professional engine builder, but have bu...   Feb 6 2023, 07:36 AM
DRPHIL914   [quote name='930cabman' post='3044140' date='Dec...   Feb 6 2023, 09:38 AM
VaccaRabite   Zach My motor numbers etc are very close to you...   Feb 8 2023, 09:37 AM
DRPHIL914   Zach My motor numbers etc are very close to yo...   Feb 8 2023, 09:45 AM
BeatNavy   Steve, I have a 2056 with a 9590 sitting on my gar...   Dec 9 2022, 10:50 AM
BeatNavy   I should also add that the 9590, when used with FI...   Dec 9 2022, 11:04 AM
sjhenry1075   I should also add that the 9590, when used with F...   Dec 9 2022, 12:00 PM
JamesJ   Not to pull away from OP's question, but it is...   Dec 9 2022, 12:17 PM
mepstein   Not to pull away from OP's question, but it i...   Dec 9 2022, 12:53 PM
JamesJ   You really have to figure out what made the engin...   Dec 9 2022, 06:46 PM
BeatNavy   If the car was running like a champ, then I wouldn...   Dec 9 2022, 06:58 PM
sjhenry1075   You really have to figure out what made the engi...   Dec 9 2022, 08:54 PM
barnfind9141972   You really have to figure out what made the eng...   Dec 10 2022, 01:09 AM
sjhenry1075   [quote name='sjhenry1075' date='Dec 9...   Dec 10 2022, 09:35 AM
BeatNavy   Yeah, in and of itself, the higher CR wouldn't...   Dec 9 2022, 01:58 PM
JamesJ   @sjhenry1075 Jorge at EM is the one who built my...   Dec 10 2022, 11:06 AM
Montreal914   Jorge at EM is the one who built my engine. I had...   Dec 10 2022, 01:53 PM
JamesJ   Jorge at EM is the one who built my engine. I ha...   Dec 10 2022, 11:21 PM
sjhenry1075   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Dec 10 2022, 07:26 PM
JeffBowlsby   [b]@[url=http://www.914world.com/bbs2/index.php?...   Dec 10 2022, 11:47 PM
sjhenry1075   [quote name='sjhenry1075' post='3044488' date='De...   Dec 11 2022, 08:17 AM
Geezer914   2056, 9550 cam, Hoffman RS heads, 9:1 CR, 50 mm mo...   Feb 6 2023, 10:35 AM
- Lo-Fi Version Time is now: 17th October 2026 - 02:25 AM
