| sjhenry1075 |
Dec 8 2022, 09:22 AM
Member ![]() ![]() Group: Members Posts: 270 Joined: 22-July 12 From: Stevensville, MD Member No.: 14,709 Region Association: North East States
Hey everyone,
I'm in the process of sourcing parts for my 2056 build. I was able to find 2.0 heads that will be rebuilt by a local machine shop, and I found a set of very nice 40 IDF Weber carbs. I'll also be using my 1.7 case. My question is this: for the engine internals, where can I find these parts? I did see on the Fat Rimco website that they sell a short block kit for $2650 that includes the following: FAT Camshaft FC 442 Camshaft / FC 440 If Smog 71mm Type 4 Crankshaft 2.0 Connecting Rods - Rebuilt 96mm Forged Pistons & Cylinders - Keith Black WEB Lifters Front Oil Seal Rear Main Seal Gasket Set - German Engine Hardware Kit - Nuts & Bolts Main Bearings - Silverline Rod Bearings - Mahle HD Double Thrust Cam Bearings (2 Sets of STD) What does everyone think about the price? I know some would not refer Fat Rimco for an engine build, but they will just supply the parts, not doing the actual build. Thoughts? |
| JamesJ |
Dec 10 2022, 11:06 AM
Member ![]() ![]() Group: Members Posts: 296 Joined: 30-April 20 From: Sunnyvale, CA Member No.: 24,202 Region Association: Northern California
@sjhenry1075
Jorge at EM is the one who built my engine. I had to fix some things that were not done properly by EM prior to my engine installation and I am not the only one on World who has had problems with EM. Cost wise he is too far away for me to pay to have the engine returned to him and shipped back to me. I may video the engine disassembly so both parties can agree on the problem. @BeatNavy Thanks for the input on the compression ratio. It was running great, but for longevity purposes I richened up the fuel mixture just a hair so that it will run a bit cooler. |
| Montreal914 |
Dec 10 2022, 01:53 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,207 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
Jorge at EM is the one who built my engine. I had to fix some things that were not done properly by EM prior to my engine installation and I am not the only one on World who has had problems with EM. Cost wise he is too far away for me to pay to have the engine returned to him and shipped back to me. I may video the engine disassembly so both parties can agree on the problem. @JamesJ When you figure out what made your engine lock, please share. (IMG:style_emoticons/default/beerchug.gif) |
sjhenry1075 Parts for 2056 Dec 8 2022, 09:22 AM
Montreal914 Parts and machining: European Motorworks in Hawtho... Dec 8 2022, 10:05 AM
930cabman All good suggestions, may I add:
D Elgin camshaft... Dec 8 2022, 10:22 AM
914werke If you local machine shop has the ability to do th... Dec 8 2022, 11:16 AM
sjhenry1075
If you local machine shop has the ability to do t... Dec 8 2022, 11:21 AM
sportlicherFahrer I picked up a nice set of pistons and cylinders an... Dec 8 2022, 11:28 AM
barefoot You didn't mention any work needed on the case... Dec 8 2022, 03:59 PM
mepstein Billy Ring
Performance auto works
Kerneysville WV
... Dec 8 2022, 04:56 PM
BeatNavy
Billy Ring
Kerneysville WV... Dec 8 2022, 07:25 PM
sjhenry1075
Billy Ring
Kerneysville W... Dec 9 2022, 05:57 AM
BeatNavy There's a ton of people here who can wax more ... Dec 9 2022, 06:34 AM
sjhenry1075
There's a ton of people here who can wax more... Dec 9 2022, 08:48 AM
VaccaRabite
Don't you have a 2056? What cam did you use?... Dec 9 2022, 10:00 AM
sjhenry1075
Don't you have a 2056? What cam did you use... Dec 9 2022, 10:08 AM
930cabman I am no professional engine builder, but have buil... Dec 9 2022, 08:48 AM
barringtonpro
I am no professional engine builder, but have bui... Feb 6 2023, 06:59 AM
VaccaRabite
I am no professional engine builder, but have bu... Feb 6 2023, 07:36 AM
DRPHIL914
[quote name='930cabman' post='3044140' date='Dec... Feb 6 2023, 09:38 AM
VaccaRabite
Zach
My motor numbers etc are very close to you... Feb 8 2023, 09:37 AM
DRPHIL914
Zach
My motor numbers etc are very close to yo... Feb 8 2023, 09:45 AM
BeatNavy Steve, I have a 2056 with a 9590 sitting on my gar... Dec 9 2022, 10:50 AM
BeatNavy I should also add that the 9590, when used with FI... Dec 9 2022, 11:04 AM
sjhenry1075
I should also add that the 9590, when used with F... Dec 9 2022, 12:00 PM
JamesJ Not to pull away from OP's question, but it is... Dec 9 2022, 12:17 PM
Not to pull away from OP's question, but it i... Dec 9 2022, 12:53 PM
JamesJ
You really have to figure out what made the engin... Dec 9 2022, 06:46 PM
BeatNavy If the car was running like a champ, then I wouldn... Dec 9 2022, 06:58 PM
sjhenry1075
You really have to figure out what made the engi... Dec 9 2022, 08:54 PM
barnfind9141972
You really have to figure out what made the eng... Dec 10 2022, 01:09 AM
sjhenry1075
[quote name='sjhenry1075' date='Dec 9... Dec 10 2022, 09:35 AM
BeatNavy Yeah, in and of itself, the higher CR wouldn't... Dec 9 2022, 01:58 PM
JamesJ
Jorge at EM is the one who built my engine. I ha... Dec 10 2022, 11:21 PM
sjhenry1075
[b]@[url=http://www.914world.com/bbs2/index.php?s... Dec 10 2022, 07:26 PM
JeffBowlsby
[b]@[url=http://www.914world.com/bbs2/index.php?... Dec 10 2022, 11:47 PM
sjhenry1075
[quote name='sjhenry1075' post='3044488' date='De... Dec 11 2022, 08:17 AM
Geezer914 2056, 9550 cam, Hoffman RS heads, 9:1 CR, 50 mm mo... Feb 6 2023, 10:35 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th October 2026 - 02:27 AM |
