| Type 47 |
Dec 10 2022, 07:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 792 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None
It was super cool to get behind the wheel, even though I'm sitting on a 6x6 piece of wood.
so bleeding the master and front went OK; we got nothing on the backs. I suspect the brake pressure regulator needs to be wacked or something. Please advise before I do something stupid. Some videos show a different BPR, this is a 75' |
| Type 47 |
Dec 12 2022, 08:21 PM
So is the BPR adjustable??
the alien screw and nut on the left indicates it should be, but it was not possible to move without rounding off the nut. |
Type 47 finally got behind the wheel to bleed brakes Dec 10 2022, 07:31 PM
PatMc
It was super cool to get behind the wheel, even t... Dec 11 2022, 12:48 PM
Type 47
It was super cool to get behind the wheel, even ... Dec 11 2022, 05:05 PM
troth The first time my dad showed me how to bleed brake... Dec 11 2022, 01:17 PM
PatMc
The first time my dad showed me how to bleed brak... Dec 11 2022, 03:10 PM
Type 47
The first time my dad showed me how to bleed brak... Dec 11 2022, 05:03 PM
FlacaProductions Are your rear soft hoses expanded closed/clogged? Dec 11 2022, 01:24 PM
Type 47
Are your rear soft hoses expanded closed/clogged?... Dec 11 2022, 05:04 PM
Superhawk996 Regulator is set at at a specific brake pressure k... Dec 13 2022, 06:02 AM
rhodyguy Get Speed Bleeders (PMB?), a long length of clear ... Dec 13 2022, 08:59 AM
rjames
Get Speed Bleeders (PMB?), a long length of clear... Dec 13 2022, 10:25 AM
Type 47
Get Speed Bleeders (PMB?), a long length of clea... Dec 13 2022, 12:54 PM
rjames You might have better luck using a pressure bleede... Dec 13 2022, 02:41 PM
Type 47
You might have better luck using a pressure bleed... Dec 14 2022, 05:03 PM
sixnotfour If the MC is oldder the piston can get stuck in th... Dec 13 2022, 04:54 PM
Type 47
If the MC is oldder the piston can get stuck in t... Dec 14 2022, 05:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 10:35 PM |
