| Type 47 |
Dec 10 2022, 07:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 792 Joined: 1-June 10 From: St. Louis, MO Member No.: 11,790 Region Association: None
It was super cool to get behind the wheel, even though I'm sitting on a 6x6 piece of wood.
so bleeding the master and front went OK; we got nothing on the backs. I suspect the brake pressure regulator needs to be wacked or something. Please advise before I do something stupid. Some videos show a different BPR, this is a 75' |
| rhodyguy |
Dec 13 2022, 08:59 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Get Speed Bleeders (PMB?), a long length of clear tubing that fits the SBs (long enough to reach the floor outside the driver’s side door from the right rear) and a catch jar. Makes bleeding the brakes a one person job as you sit in the driver’s seat with the door open. No telling the helper ‘pump, pump, pump, hold, release’ repeatedly. Right rear, left rear, right front, left front. That order. You will see air bubbles going down the line. Get a big bottle of brake fluid. Don’t bleed the reservoir to empty.
Type 47 finally got behind the wheel to bleed brakes Dec 10 2022, 07:31 PM
PatMc
It was super cool to get behind the wheel, even t... Dec 11 2022, 12:48 PM
Type 47
It was super cool to get behind the wheel, even ... Dec 11 2022, 05:05 PM
troth The first time my dad showed me how to bleed brake... Dec 11 2022, 01:17 PM
PatMc
The first time my dad showed me how to bleed brak... Dec 11 2022, 03:10 PM
Type 47
The first time my dad showed me how to bleed brak... Dec 11 2022, 05:03 PM
FlacaProductions Are your rear soft hoses expanded closed/clogged? Dec 11 2022, 01:24 PM
Type 47
Are your rear soft hoses expanded closed/clogged?... Dec 11 2022, 05:04 PM
Type 47 So is the BPR adjustable??
the alien screw and nu... Dec 12 2022, 08:21 PM
Superhawk996 Regulator is set at at a specific brake pressure k... Dec 13 2022, 06:02 AM
rjames
Get Speed Bleeders (PMB?), a long length of clear... Dec 13 2022, 10:25 AM
Type 47
Get Speed Bleeders (PMB?), a long length of clea... Dec 13 2022, 12:54 PM
rjames You might have better luck using a pressure bleede... Dec 13 2022, 02:41 PM
Type 47
You might have better luck using a pressure bleed... Dec 14 2022, 05:03 PM
sixnotfour If the MC is oldder the piston can get stuck in th... Dec 13 2022, 04:54 PM
Type 47
If the MC is oldder the piston can get stuck in t... Dec 14 2022, 05:04 PM![]() ![]() |
Lo-Fi Version | Time is now: 7th December 2025 - 10:36 PM |
