CptTripps |
:: Punch and Pie :: ![]() ![]() ![]() ![]() Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest ![]() |
Gang,
I yanked the entire interior out tonight and was planning on just sanding it down a little and then re-spraying it before I re-build the rest of the interior. (one of the winter projects.) I had an idea for the interior, and the front and rear trunks. (Or boots...whatever.) I had an assistant a while ago that had these guys spray a bedliner into his new truck. Took them about a day, and it was REAL solid. The nice part was that it was impervious to lots of chemicals, and completely waterproof. http://216.28.21.48/cgi-bin/permatech.cgi/.../Tech_Info/A/55 That's the technical part, but I remember at the shop, they had a ton of stuff that they'd sprayed with the stuff. There is an off-road magazine that had them do the OUTSIDE of their truck because it was so great with chips and stuff. I'm thinking that it may add 30-40lbs to the car, but it'll never rust through, and if I get it done in Yellow, might actually look real nice too. I'm also thinking it'll quiet the interior up a bit. I think his truck bed cost like $250 (4yrs ago) and I can't imagine it'll take any more than that. Think it's a good idea? Or am I REALLY crazy? |
John |
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None ![]() |
I had a similar thought, with a twist...
The track car (that is all it does) ends up with "stars" on the fenders where stones are thrown by the tires into the insides of the steel flares. Hopefully this stuff will prevent some of this from happening... I am considering spraying the inside of the fenders with the stuff to see if it gets sandblasted away like all the paint in the inner fenderwells does. It may add a few pounds but I kinda doubt it will add too much weight if only used in the problem areas of the inner fender wells. Damn sticky tires. |
Lo-Fi Version | Time is now: 15th June 2024 - 05:22 PM |
