How did you mount dual pole oil pressure sender |
cgnj |
Jul 12 2022, 08:28 AM
Senior Member Group: Members Posts: 627 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Almost ready to wake up the 2270 after dropping the motor to change oil pump & oil pressure relief circuit. How and where did you mount the dual pole sender. I am using a braided steel hose.
Thanks in advance |
VaccaRabite |
Dec 22 2022, 08:08 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
You will notice a lot of people that started with dual pole senders have moved back to a T joint, a sender for the pressure gauge and a stock sender for the idiot light.
The issue is that the idiot light turns on at about 4PSI, and the dual pole will light up around 10PSI. Which can mean you have a flickering oil light on a hot engine at idle, which is disconcerting. Its one of those things where if you don't drive the car much or very long, or you make really good pressure, a dual pole is fine. But if you drive the car long enough for the oil to really come up to temp on a stock oil pump, you may find your oil light on, even though you have okay pressure. |
friethmiller |
Dec 22 2022, 01:47 PM
Senior Member Group: Members Posts: 506 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region |
You will notice a lot of people that started with dual pole senders have moved back to a T joint, a sender for the pressure gauge and a stock sender for the idiot light. The issue is that the idiot light turns on at about 4PSI, and the dual pole will light up around 10PSI. Which can mean you have a flickering oil light on a hot engine at idle, which is disconcerting. Its one of those things where if you don't drive the car much or very long, or you make really good pressure, a dual pole is fine. But if you drive the car long enough for the oil to really come up to temp on a stock oil pump, you may find your oil light on, even though you have okay pressure. This is so true! I'm going to a split setup (idiot light and single pole sender). I currently have a dual pole installed and once hot, the oil pressure light flickers/comes on. It's even worse when the A/C is running which draws the rpms down a bit more. |
Lo-Fi Version | Time is now: 10th June 2024 - 05:35 PM |
