How did you mount dual pole oil pressure sender |
cgnj |
Jul 12 2022, 08:28 AM
Senior Member Group: Members Posts: 627 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None |
Almost ready to wake up the 2270 after dropping the motor to change oil pump & oil pressure relief circuit. How and where did you mount the dual pole sender. I am using a braided steel hose.
Thanks in advance |
dr914@autoatlanta.com |
Jul 12 2022, 11:21 AM
914 Guru Group: Members Posts: 7,898 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
go to the auto parts store and get a brass fitting with pipe threads to extend the oil pressure sending switch hole up and then screw in the sending unit
Almost ready to wake up the 2270 after dropping the motor to change oil pump & oil pressure relief circuit. How and where did you mount the dual pole sender. I am using a braided steel hose. Thanks in advance |
brant |
Jul 12 2022, 04:26 PM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
go to the auto parts store and get a brass fitting with pipe threads to extend the oil pressure sending switch hole up and then screw in the sending unit Almost ready to wake up the 2270 after dropping the motor to change oil pump & oil pressure relief circuit. How and where did you mount the dual pole sender. I am using a braided steel hose. Thanks in advance I’ve seen similar set ups fail And don’t recommend this set up Brass will work harden and crack over time. Usually at the threads. Especially with the sender weight on top A flexible hose will dampen the vibration Brant |
ClayPerrine |
Dec 22 2022, 03:08 PM
Life's been good to me so far..... Group: Admin Posts: 15,525 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
go to the auto parts store and get a brass fitting with pipe threads to extend the oil pressure sending switch hole up and then screw in the sending unit Almost ready to wake up the 2270 after dropping the motor to change oil pump & oil pressure relief circuit. How and where did you mount the dual pole sender. I am using a braided steel hose. Thanks in advance I’ve seen similar set ups fail And don’t recommend this set up Brass will work harden and crack over time. Usually at the threads. Especially with the sender weight on top A flexible hose will dampen the vibration Brant Brant... I have had hoses fail... even high pressure grease gun hoses. So I use the same setup George does. But I make sure the heavy gauge sender is off the side of the t fitting, and that it is supported with a padded clamp mounted to the engine tin. So it does not vibrate and work harden the brass. Watching a 50 psi spray of hot oil whip the hose around and coat everything in the engine compartment with hot oil (including me) is scary. Clay |
Lo-Fi Version | Time is now: 11th June 2024 - 11:37 AM |
