| r_towle |
Jan 14 2023, 01:25 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I have a side shifter that leaks at the console.
I cold drip every hour… I bought the transmission gasket set from pelican There is nothing in the set for the shifter console….nada I removed the console It looks like there is a bushing at the bottom. Does anyone have a clue on part numbers to order to rebuild the shifter console? It’s a 75/76 if that matters. Rich |
| Dr Evil |
Jan 17 2023, 08:19 PM
Send me your transmission! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 23,041 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region
Do not use the paper gasket under the console. That is a part for the tail shift only and goes on the side plug which does not use the O ring. Note in the above diagram the missing gasket, because its not used and using it can cause issues. Just change the O ring and seal on the lower shaft and you are good to go.
| r_towle |
Jan 18 2023, 04:31 PM
Do not use the paper gasket under the console. That is a part for the tail shift only and goes on the side plug which does not use the O ring. Note in the above diagram the missing gasket, because its not used and using it can cause issues. Just change the O ring and seal on the lower shaft and you are good to go. Cool. Explains why it was not in the gasket kit! |
r_towle Shifter console leaking Jan 14 2023, 01:25 PM
Montreal914 Here is an exploded view of the assembly (found on... Jan 14 2023, 02:03 PM
r_towle Thank you!
While I am there….
Do you think ... Jan 14 2023, 02:06 PM
Montreal914 Sorry, I made a mistake!!!
You are co... Jan 14 2023, 02:20 PM
r_towle I will take it apart and see what I need.
It’s w... Jan 14 2023, 02:34 PM
930cabman Having the same issue and dis assembled it today. ... Jan 14 2023, 06:09 PM
r_towle
Having the same issue and dis assembled it today.... Jan 14 2023, 06:48 PM
930cabman
Having the same issue and dis assembled it today... Jan 16 2023, 10:33 AM
Dave_Darling May? It will; it comes out as a unit. The rake h... Jan 16 2023, 10:36 PM
r_towle Btdt, no swearing required when in neutral.
Got it... Jan 16 2023, 10:54 PM
Dave_Darling There's just the slightest possibility I was e... Jan 17 2023, 05:06 PM
r_towle
There's just the slightest possibility I was ... Jan 18 2023, 04:32 PM
930cabman Yes, the shaft #13 with rake attached did come out... Jan 17 2023, 05:34 PM
930cabman How did you remove the small oil seal from it... Jan 18 2023, 06:29 PM
Chaznaster Maybe use a seal puller? Runs less risk of damagin... Jan 18 2023, 07:57 PM
930cabman
Maybe use a seal puller? Runs less risk of damagi... Jan 19 2023, 05:54 AM
r_towle If it’s the rubber seal I think it is from the k... Jan 18 2023, 08:51 PM
914werke
Maybe use a seal puller? Runs less risk of damagi... Jan 18 2023, 10:09 PM
Mikey914 Got what you need
https://914rubber.com/shift-ro... Jan 18 2023, 11:01 PM
r_towle Ok, it is wicked cold and raw here.
I really need ... Jan 22 2023, 01:03 PM
r_towle These Jan 22 2023, 01:11 PM
Montreal914 Perfect opportunity to convert the shifter console... Jan 22 2023, 01:43 PM
r_towle
Perfect opportunity to convert the shifter consol... Jan 22 2023, 01:51 PM
930cabman
Perfect opportunity to convert the shifter conso... Jan 22 2023, 04:33 PM
r_towle Very slight side to side wiggle…
Not enough to c... Jan 22 2023, 09:56 PM
930cabman "Crushed and damaged" O ring would indic... Jan 23 2023, 05:56 AM
r_towle It was certainly leaking from the housing due to t... Jan 23 2023, 03:09 PM
r_towle Drove up to my local dealer.
Pet2 lists the o-ring... Jan 24 2023, 02:44 PM
r_towle measured the housing groove, its 2.25mm
measure th... Jan 24 2023, 03:05 PM
930cabman I was at my local bearing house today and picked u... Jan 24 2023, 05:46 PM
r_towle There is no paper gasket in any diagram I have see... Jan 24 2023, 06:31 PM
930cabman
There is no paper gasket in any diagram I have se... Jan 24 2023, 06:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 05:58 PM |
