| r_towle |
Jan 14 2023, 01:25 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
I have a side shifter that leaks at the console.
I cold drip every hour… I bought the transmission gasket set from pelican There is nothing in the set for the shifter console….nada I removed the console It looks like there is a bushing at the bottom. Does anyone have a clue on part numbers to order to rebuild the shifter console? It’s a 75/76 if that matters. Rich |
| r_towle |
Jan 22 2023, 01:03 PM
Ok, it is wicked cold and raw here.
I really need a huge shop heater….but the construction kerosene heater makes it tolerable. Of course the part in question has been in the parts cleaner soaking….so it is at 30 degrees to touch..awesome times. I learned two things. The o-ring around the housing was torn and mutilated. The shaft seal was 47 years old and no longer up to the task. I’m not convinced the “transmission gasket kit” has the right o-ring diameter, so I will do some deeper research on that. Not sure where yet. To pull the shaft seal I used a combination of a few steps. 1: tear out the rubber seal 2: take an old wood chisel and carefully put a cut in the metal top lip of the seal, without touching the housing 3: prying at that point still did nothing 4: map gas torch, heated up (it will catch on fire, there is still rubber and grease…be prepared 5: pry after heat and it popped out (after I put out the fires…. Nothing major) |
r_towle Shifter console leaking Jan 14 2023, 01:25 PM
Montreal914 Here is an exploded view of the assembly (found on... Jan 14 2023, 02:03 PM
r_towle Thank you!
While I am there….
Do you think ... Jan 14 2023, 02:06 PM
Montreal914 Sorry, I made a mistake!!!
You are co... Jan 14 2023, 02:20 PM
r_towle I will take it apart and see what I need.
It’s w... Jan 14 2023, 02:34 PM
930cabman Having the same issue and dis assembled it today. ... Jan 14 2023, 06:09 PM
r_towle
Having the same issue and dis assembled it today.... Jan 14 2023, 06:48 PM
930cabman
Having the same issue and dis assembled it today... Jan 16 2023, 10:33 AM
Dave_Darling May? It will; it comes out as a unit. The rake h... Jan 16 2023, 10:36 PM
r_towle Btdt, no swearing required when in neutral.
Got it... Jan 16 2023, 10:54 PM
Dave_Darling There's just the slightest possibility I was e... Jan 17 2023, 05:06 PM
r_towle
There's just the slightest possibility I was ... Jan 18 2023, 04:32 PM
930cabman Yes, the shaft #13 with rake attached did come out... Jan 17 2023, 05:34 PM
Dr Evil Do not use the paper gasket under the console. Tha... Jan 17 2023, 08:19 PM
r_towle
Do not use the paper gasket under the console. Th... Jan 18 2023, 04:31 PM
930cabman How did you remove the small oil seal from it... Jan 18 2023, 06:29 PM
Chaznaster Maybe use a seal puller? Runs less risk of damagin... Jan 18 2023, 07:57 PM
930cabman
Maybe use a seal puller? Runs less risk of damagi... Jan 19 2023, 05:54 AM
r_towle If it’s the rubber seal I think it is from the k... Jan 18 2023, 08:51 PM
914werke
Maybe use a seal puller? Runs less risk of damagi... Jan 18 2023, 10:09 PM
Mikey914 Got what you need
https://914rubber.com/shift-ro... Jan 18 2023, 11:01 PM
r_towle These Jan 22 2023, 01:11 PM
Montreal914 Perfect opportunity to convert the shifter console... Jan 22 2023, 01:43 PM
r_towle
Perfect opportunity to convert the shifter consol... Jan 22 2023, 01:51 PM
930cabman
Perfect opportunity to convert the shifter conso... Jan 22 2023, 04:33 PM
r_towle Very slight side to side wiggle…
Not enough to c... Jan 22 2023, 09:56 PM
930cabman "Crushed and damaged" O ring would indic... Jan 23 2023, 05:56 AM
r_towle It was certainly leaking from the housing due to t... Jan 23 2023, 03:09 PM
r_towle Drove up to my local dealer.
Pet2 lists the o-ring... Jan 24 2023, 02:44 PM
r_towle measured the housing groove, its 2.25mm
measure th... Jan 24 2023, 03:05 PM
930cabman I was at my local bearing house today and picked u... Jan 24 2023, 05:46 PM
r_towle There is no paper gasket in any diagram I have see... Jan 24 2023, 06:31 PM
930cabman
There is no paper gasket in any diagram I have se... Jan 24 2023, 06:59 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 06:00 PM |
