Rear Main Seal Leak, Or Not.. |
Olympic 914 |
Mar 29 2018, 01:57 PM
Group: Members Posts: 1,675 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
Noticed a couple drips under the engine, and it didn't smell like trans fluid. So I of course suspected a rear main seal leak. Now this engine only has just over 2K miles on it from a total rebuild. and I just had it out to repair a broken rocker arm stud over the winter. I didn't remove the flywheel at that time so the seal hasn't been disturbed since being put together.
But when I pulled it apart I found the area below the seal was dry. closer inspection revealed that the oil galley plugs I installed had leaked. Definite wet on the left plug in this picture and a little oil on the far right one. I used some liquid Teflon pipe thread sealant when I put them in. I was thinking of using some of the HondaBond case sealant this time. I used that on the case halves. and it seem to be holding up okay. The seal I put in originally was a Victor Reinz seal and I ordered another before I even pulled the engine. Now I wonder if I should just leave that seal in? it only has 2K miles. OR pull it out replace it and maybe check the crank endplay again while I have it apart. I am leaning towards ... Leaving well enough alone, and just resealing the oil gallery plugs. and leaving the rear seal in there. What is your opinion ?? |
TheCabinetmaker |
Mar 29 2018, 06:04 PM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I use Teflon paste. Never had one leak. I won't use the vr seals either. The Sabo black is the only one I use
914sgofast2 |
Jan 23 2023, 11:49 AM
Senior Member Group: Members Posts: 623 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
DRPHIL914 |
Jan 23 2023, 11:51 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
I use Teflon paste. Never had one leak. I won't use the vr seals either. The Sabo black is the only one I use I second the use of the black Sabo brand of rear main seal. I've been looking all over and cant find one, not on GoWesty or anywere. |
rjames |
Jan 23 2023, 02:44 PM
I'm made of metal Group: Members Posts: 3,955 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest |
I use Teflon paste. Never had one leak. I won't use the vr seals either. The Sabo black is the only one I use I second the use of the black Sabo brand of rear main seal. I've been looking all over and cant find one, not on GoWesty or anywere. According to GoWesty the Elring model is the one to use. |
DRPHIL914 |
Jan 23 2023, 07:00 PM
I use Teflon paste. Never had one leak. I won't use the vr seals either. The Sabo black is the only one I use I second the use of the black Sabo brand of rear main seal. I've been looking all over and cant find one, not on GoWesty or anywere. According to GoWesty the Elring model is the one to use. i finally found the article and their most recent update in 2021 now says it’s Eherling, the SABO not as good anymore due to age and degradation of the mold used to make the seal, so it’s no longer a perfect fit like used to hope this link helps others . https://gowesty.com/blogs/article-library/f...main-seal-story Phil -EDIT: sorry just saw that you had the same link imbedded in your post too. |
Lo-Fi Version | Time is now: 8th June 2024 - 02:13 AM |
