 Forum Rules Classified Rules!
> FS- 1974 914-V8
MM1
post Jan 22 2023, 12:04 AM
914 obsession continues
1974 Porsche 914-V8 for sale. It originally was L80E Ivory White.
Asking $14,500 OBO
Current odometer: 83,118+ (still driving it). True mileage unknown. I have driven it approximately 500+ miles since recommissioning/upgrading it.
Never wrecked (!)
Videos:
Porsche 914-V8 drive
https://www.youtube.com/watch?v=_qrQEGfp0xk
Porsche_914-V8_walkaround
https://www.youtube.com/watch?v=FJ8ZQxCaNUs
Porsche_914-V8_cold start
https://www.youtube.com/watch?v=6XFeT7puGDo
Porsche_914-V8_wheel trueness
https://www.youtube.com/watch?v=AQh6dP_UZjA
Porsche_914-V8_shifting
https://www.youtube.com/watch?v=r-LMYwZbfhk
1965 Chevrolet 283 c.i. V8 - 195-220 h.p., 285-295 lb./ft of torque, rams horn exhaust manifolds (no maintenance, allows for room to work), Edelbrock Performer intake manifold with Edelbrock 1406 (Holly 8867) 4-barrel carburetor
***Will idle for +30 minutes at rest with no issues.
Provenance: records and receipts dating back to 2002
BMW 320i front brakes with 19mm brake master cylinder
*New parts installed:
Uro 19mm brake master cylinder
PMB refurbished rear brake calipers
Porterfield R4-S brake pads (front and rear)
Passenger parking brake cable (Gemo)
parking brake cable grommets at caliper (both sides)
correct year new fuel tank (new fuel socks, copper gaskets, sending unit, gates green stripe and continental fuel hoses, fuel filters)
Moroso combination coolant expansion tank/overflow tank, mounted at the car's highest point in the engine bay
water inlets (engine block) re-sealed (Fel-Pro gaskets and Permatex thread sealant with activator)
Gates green stripe coolant hoses with stainless t-bar clamps, fittings
mishimoto billet aluminum bleeder fitting in engine compartment (can be lifted to highest position for bleeding)
bleeder valve for radiator in front
Davies-Craig electric water pump
new hei distributor cap, rotor, ignition module, wires, spark plugs with heat shields
chrome air cleaner with new filter
chrome valve covers and clamps with Fel-Pro 1628 silicone valve cover gaskets
mobil 1 oil change with wix filter
4 new (sticky) Falken Azenis 615K+ tires (205/50-15) with less than 500 miles of use.
numerous oem original used interior parts (A and B pillars, knee pad, door pulls etc.)
Momo steering wheel
Battery
shifter bushings
tailshifter firewall cover rubber bellows
Cleaned and repaired door handles
One Porsche key (red) works in all locks.
All driving lights/blinkers function.
Jack points are great.
Weltmeister short shift kit
new Renegade Hybrids front spoiler mounted
Currently registered in California with a clean title in my name.
Sounds great, steers straight and responsively, brakes great, starts and revs eagerly . . .great chassis and engine . . .I drove it 100 miles in the rain the other night with no issues (other than the driver's wiper calling it a day - grrr/lol)
Tailshifter - 1st gear is locked out, needs to be resealed. If I were keeping it I'd fit a cable shifter. Hard to get second when cold (and if it is in a bad mood). 4th will occasionally grind if rushed.
283 weeps slightly at oil adapter (new gasket should fix it), pan gasket weeps slightly
Paint is peeling and there are rust bubbles (see pics)
Driver wiper doesn't work.
Rear passenger triangle/false firewall rusted through, but has not affected the integrity of the longs or even the passenger rear "doughnut" (which can still be used to lift the car even though it is not a factory jackpoint).
Holley Inc. said it should have a 390cfm (2-barrel) but that won't fit easily . . .the currently installed Edelbrock (weber) 4 barrel = slight over carburation. Choke is disconnected.
Please note:
**** ATS wheels seen in the driving video are NOT included - 4 very straight and true OEM Pedrini rims are currently installed on the new Falken Azenis tires****
Some process pics below show old yellow spark plug wires, old hei distributor cap/vacuum advance etc. and old Odyssey PC1200 agm battery . . .all have been replaced.
PM if interested in making an offer . . .I have nearly 1500 photographs and a few videos of the recommissioning/re-engineering process.
Attached ImageAttached ImageAttached Image
Front yard mechanic
post Jan 23 2023, 07:23 PM
Nice car needs more console gauges tho (IMG:style_emoticons/default/slap.gif)
MM1   FS- 1974 914-V8   Jan 22 2023, 12:04 AM
MM1   RE: FS- 1974 914-V8   Jan 22 2023, 01:13 AM
MM1   RE: FS- 1974 914-V8   Jan 22 2023, 01:16 AM
MM1   RE: FS- 1974 914-V8   Jan 22 2023, 01:20 AM
MM1   RE: FS- 1974 914-V8   Jan 22 2023, 01:26 AM
MM1   RE: FS- 1974 914-V8   Jan 22 2023, 01:31 AM
MM1   ***Current non-agm battery below*** *** This...   Jan 22 2023, 02:29 AM
MM1   RE: FS- 1974 914-V8   Jan 22 2023, 02:40 AM
MM1   Renegade veteran guru suggested these holes be dri...   Jan 22 2023, 02:45 AM
MM1   Shifter bushings, bellows, and cover installations...   Jan 22 2023, 02:48 AM
MM1   Rockers and jackpoints:   Jan 22 2023, 02:51 AM
MM1   Rockers and jackpoints (continued):   Jan 22 2023, 02:56 AM
MM1   Rockers and jackpoints (further continued ):   Jan 22 2023, 02:59 AM
MM1   Undercarriage:   Jan 22 2023, 03:03 AM
MM1   Undercarriage (2):   Jan 22 2023, 03:06 AM
MM1   Undercarriage (3):   Jan 22 2023, 03:10 AM
MM1   cv axle/boots:   Jan 22 2023, 03:11 AM
MM1   Sorry-it was an extremely long day yesterday. Dea...   Jan 22 2023, 08:15 AM
willieg   Very nice job of documentation through pictures.   Jan 23 2023, 09:39 AM
MM1   Very nice job of documentation through pictures. ...   Jan 23 2023, 08:37 PM
JeffBowlsby   @MM1 The 17916 VIN on this 1974 originally L80E ...   Jan 23 2023, 02:06 PM
MM1   [b]@[url=http://www.914world.com/bbs2/index.php?s...   Jan 23 2023, 08:45 PM
JeffBowlsby   [b]@[url=http://www.914world.com/bbs2/index.php?...   Jan 23 2023, 11:14 PM
MM1   [quote name='MM1' post='3053188' date='Jan 23 202...   Jan 23 2023, 11:35 PM
JamesM   Is it really an actual LE spolier though? I thou...   May 9 2023, 04:17 PM
JamesM   Is it really an actual LE spolier though? I tho...   May 9 2023, 04:20 PM
Front yard mechanic   Nice car needs more console gauges tho :stooges:   Jan 23 2023, 07:23 PM
MM1   Nice car needs more console gauges tho :stooges: ...   Jan 23 2023, 08:51 PM
Robarabian   Ill add for any potential buyer: I drove Marcus u...   Jan 23 2023, 09:00 PM
MM1   Ill add for any potential buyer: I drove Marcus ...   Jan 23 2023, 09:09 PM
pete000   Rod Stimson build possibly?   Jan 24 2023, 07:16 PM
budk   IF the air dam turns out to be an original LE one,...   Jan 25 2023, 08:13 AM
JeffBowlsby   Bud, thank you! Marcus's spoiler is the r...   Jan 25 2023, 10:50 AM
MM1   Thank you Jeff and Bud. After some pics and disc...   Jan 26 2023, 01:15 PM
flat4guy   What a cool car - unfortunately I am looking for o...   Jan 26 2023, 09:10 PM
MM1   What a cool car - unfortunately I am looking for ...   Jan 26 2023, 10:25 PM
MM1   Ok - my first (ever) posted youtube video is avail...   Jan 27 2023, 10:52 PM
MM1   I mounted a new 914 Renegade front spoiler 2 days ...   Jan 29 2023, 08:02 PM
MM1   :bump:   Feb 1 2023, 02:44 PM
MM1   Price drop before it goes to auction . . . very s...   Feb 11 2023, 01:06 AM
MM1   @RobArabian and I did our best to represent the s...   Feb 12 2023, 04:22 PM
MM1   “Red, I” in Irish Green . . . at the stoplight...   Feb 12 2023, 04:29 PM
Robarabian   That's you in my rear view mirror!!...   Feb 12 2023, 10:19 PM
MM1   Oh yeah, btw-it was 40° when I left this morning ...   Feb 12 2023, 04:37 PM
MM1   “True dat”, my friend! :beer2: Thank yo...   Feb 12 2023, 11:58 PM
MM1   :red914:   Feb 19 2023, 06:56 PM
rhodyguy   Best sleeper ever. GLWTS.   Feb 20 2023, 08:15 PM
MM1   Best sleeper ever. GLWTS. Thank you, Sir - fun...   Feb 21 2023, 12:56 PM
MM1   Asking $14,500 OBO - need it gone asap - othe...   May 6 2023, 06:39 PM
MM1   :bump:   May 9 2023, 01:26 PM
Mike1981   Hello I have been following this thread. Is thi...   Jun 20 2023, 05:41 PM
Robarabian   Mike, Yes, I hang out with Marcus quite a bit. H...   Jun 21 2023, 09:57 PM
MM1   *New parts installed: Uro 19mm brake master cylin...   Jul 3 2023, 08:19 PM
MM1   New shifting video uploaed: Porsche_914-V8_shifti...   Jul 18 2023, 08:38 AM
- Lo-Fi Version Time is now: 17th November 2026 - 06:24 PM
